I'm on a week long trip out east and am having issues with my PC-V. I bought it from Fuel Moto and have worked with tech support once already on this issue. When I'm running between 2600-2900 rpm the bike lugs on acceleration. It's not really noticeable in normal riding because you pass that range very quickly. Riding down the highway is bad though. It falls between 70-80mph. I have all intentions of working with Fuel Moto to correct the map, but I can't on my trip because I don't have my laptop.
My question is do you think there are any risks in bypassing the tuner for the rest of the week and taking care of this once I'm home?
You did not provide enough information for a really good evaluation. What kind of changes did you make to your bike, minor or radical? There is a big difference between simply adding slip on mufflers or adding an additional free flow filter and maybe a cam. The more stuff you changed, the greater the risk for running lean and possibly damaging something. How you ride it is also a factor.
Sorry, didn't realize my signature didn't come up. I have a 2010 CVO streetglide. So yes, the air cleaner is stock on the bike, but is already upgraded from the factory.
Something a tad off w/the accel fuel @ that RPM range. Your CVO was tuned fm factory for installed upgrades and original exhaust is probably similar to ProPipe so, if you can't tolerate the tuner hiccup, take it out of the picture. Worth a shot and, if it seems to run too lean/rich, can always re-connect tuner and press-on.
yeah just on plug it your fine ,a friend did that last year when he was in stugis he has a 2011 cvo and when he got home he forgot to call fuel moto for month .they send him him a new map and then was good too go ,and he is leaving again tomorrow for stugis ,oh yeah I forgot lol u do have to plug in the o2 sensers there in the right side cover
Seems to me you have a stock CVO streetglide with an aftermarket pipe, does your Pro Pipe have the O2 sensors? System should be ok to disconnect the PC-V and connect as original with the O2 Sensors. You may find the ECM adjusts and the bike will run as expected. Will be a little lean and will not have the response expected with the PC-V but should be ok. Pay attention to pre ignition ping and reinstall the PC-V if excessive.
Disconnect the large connector from PC-V and reconnect to original harness, find O2 sensors and plug into original harness under right cover. If (2) utilized, match gray to gray and black to black.
