Can I Lower My Floorboards?
Old Jul 26, 2013 | 01:08 PM
dugan's Avatar
dugan
I have the Harley Goodies kit and the HD extended floorboard pans, extended shift and brake levers.. So I'm out 1" and forward 1". Just want floorboards lowered now.
Old Jul 26, 2013 | 01:34 PM
Talldog's Avatar
Talldog
I don't recommend lowering the Boards, but this might give you a few ideas.
https://www.hdforums.com/forum/touri...with-pics.html
If you don't mind sitting a little higher, see if you've got an upholstery shop in your area that works on bike seats. I had my Tallboy seat re-worked to give me another 1 1/2" back and 1" higher.
Check with dealers in your area for a recommendation on an upholster.
Old Jul 26, 2013 | 08:02 PM
roadhog96's Avatar
roadhog96
When did Harley stop making floorboards that aren't adjustable? Mine came from the factory with 3 height adjustment for front and rear boards in 1996. Or is yours already on the lowest setting and you want them lower.
Old Jul 26, 2013 | 09:15 PM
Talldog's Avatar
Talldog
Boards on the newer Touring bikes are no longer adjustable.
Old Jul 26, 2013 | 11:26 PM
kramercars's Avatar
kramercars
http://www.tallboyscycles.com. I seen these guys at a motorcycle show and swap meet in Ohio they had a newer road glide with this kit installed for people to sit on. I am 6'1 350 lbs and have had some issues with floor board placement after sitting on their bike I was really impressed by the new location. The only thing they said was it is recommended that you lose the heal shifter because it gets in the way. These are probably on the list of mods for the winter.
Old Jul 27, 2013 | 12:16 AM
lh4x4's Avatar
lh4x4
You can do anything that you want. The question is should you?
SiggerTX
Apr 15, 2015 07:43 AM
Bigdave12768
Jul 17, 2011 06:44 PM
SixSixRider
Aug 10, 2009 05:16 PM
piasspj
Aug 6, 2009 08:28 PM
E.V.
Oct 16, 2006 04:28 AM
