I need hd forums touring section help !
at idle the charging system ( alternator and regulator) is not "adding" voltage...
as a rule of thumb the alternator produces about 16~20 volts AC ( not DC) per 1000 rpms.
then the AC current gets rectified to DC ...which burns off some volts...by the regulator- the regulator also limits the output to below 14.8 volts DC.
these are all numbers using a "real" voltmeter...not the in dash, which is as useful as an idiot light.
so at idle, the bike is really running off the battery...and maybe you'll see a reading of 12 volts or a little more measured at the battery...and this will vary depending on high beam, flashers and any other loads on the electrical system.
HEAT build up in wiring builds resistance against current flow- this is why hot starts can be difficult on any bike or car- especially if the cables are loose or corroded.
and resistance in the wiring results in even more heat...which results in more resistance and even more heat... and the snake eats it's tail and the wiring can burn up ( this is why aluminium wiring in 70's houses was/is such a bad idea)
mike
mike
so what does your gauge read that's all i asked simple.?examples 12.5v 13.5v 14v with no accessories just what a stock motorcycle has on normally BTW i put a fluke meter on against the dash gauge and it was spot on
mike
Good Luck
FLHPRK
what ever you do, do NOT make decisions based on the in-dash voltmeter.
specs for the charging system are published in the shop manual...that'll settle an argument
if my 1st response was long winded- I am fueled by "fog breaker" coffee from Fresh and Easy markets...and I thought it may be helpful for an owner to have a basic understanding of charging system function.
Mike
