3 codes and limp
Old Jul 29, 2013 | 03:57 PM
Bigdave12768's Avatar
Bigdave12768
Default 3 codes and limp
I got 1511 2135 and now 2176. Any thoughts on how to fix? I had 1511 and 2135 but after I washed it I got 2176
Old Jul 29, 2013 | 04:07 PM
Bigdave12768
I didn't get limp till I tried to clear 1511 and 2135 then limp and 2176
Old Jul 29, 2013 | 04:33 PM
josame's Avatar
josame
if you do a search on here for.. harley diagnostic codes.. there is a thread that has what the codes point to.
Old Jul 29, 2013 | 05:48 PM
UltraNutZ's Avatar
UltraNutZ
bet you have no throttle response either..
look behind your air cleaner, there is a plug there.. unplug it, blow it out real good, put dieletric grease in it, clear your codes and see what she does... probably got water in that connector...
PS.. Don't ask me how I know..
Old Jul 30, 2013 | 12:22 AM
Bigdave12768
Thx I just unplugged the ecm and cleaned and greased that. I had it fired up before that. So I am guessing your right about the water. Will do that in morning
Old Jul 30, 2013 | 04:40 AM
my67pnycar's Avatar
my67pnycar
Ditto on the air cleaner plug, it made mine throw codes because of fretting. It wouldnt hurt to check all the connections that you can see, clean and grease em. You got water in something. Here is a link for the codes.
https://www.hdforums.com/forum/elect...tic-codes.html
Old Jul 31, 2013 | 11:27 AM
Bigdave12768
how do you get that plug off? I have big hands and fingers.
Old Jul 31, 2013 | 11:28 AM
UltraNutZ's Avatar
UltraNutZ
behind the plug facing the engine is the release for it. pull the release lever towards the engine and slide the plug off.
Old Jul 31, 2013 | 11:41 PM
Sire2Twins's Avatar
Sire2Twins
I didn't get limp until...
Darn, just don't have the heart to finish the sentence. The opening was way to easy.
Old Oct 12, 2014 | 01:55 PM
Vtwinfan1969's Avatar
Vtwinfan1969
Stage I
If not fixed yet check each wire going to the tps fought this problem for several weeks wire had a break in it... Every time I rode it had to clear codes 5000 miles and no problems yet
cowboybob56
Oct 1, 2017 04:50 PM
Tortoise98
Jun 19, 2013 06:52 PM
09rkpolice
Feb 9, 2013 08:03 PM
leachman
Jun 9, 2012 06:59 AM
leohd
Oct 12, 2008 07:42 AM
