2008 FLHX Engine...
Old Jul 31, 2013 | 03:52 PM
Rapid99's Avatar
Rapid99
6th Gear
Default 2008 FLHX Engine...
Can it be installed in a 2002 FL with a 5 speed transmission? Is it a bolt in or is an adapter of some sort needed?
Thanks
Old Jul 31, 2013 | 05:03 PM
UltraNutZ's Avatar
UltraNutZ
you probably want to ask this question over in the https://www.hdforums.com/forum/gener...ech-forums-58/
Old Jul 31, 2013 | 05:39 PM
mkguitar's Avatar
mkguitar
physically it'll fit.
you'll have to figure out the ECM, wiring for the sensors etc. ( this could be expensive)
If you have a good running 88" now, a conversion to a 95" is alot easier, new pistons and cylinders and everything else remains the same but for the tuner/settings and the get up and go.
the 2008 96" is a stroked version of the twincam, when bored, it becomes the current 103"
mike
Old Jul 31, 2013 | 08:18 PM
Rapid99's Avatar
Rapid99
6th Gear
Will do...thanks!
Old Jul 31, 2013 | 08:22 PM
Rapid99's Avatar
Rapid99
6th Gear
mike
Okay, someone mentioned that the trans/engine oiling system is different between the 2 models? I replaced my 96 with a 131 and someone is interested in purchasing my stock engine that has less than 1K miles.
Thanks
Old Aug 1, 2013 | 04:19 AM
grbrown's Avatar
grbrown
Thanks
They are not interchangeable, AFAIK. The TC88s and TC96s have different arrangements to supply oil from the trans oil tank to the engine. Your 131 will be a different version to one for a TC88 bike. I don't think it is going to be easy to do without also changing the trans for a later spec one, so trans and engine mate together correctly.
Rapid99
Exhaust System Topics
Aug 1, 2013 10:08 AM
jrdstreetglide
Apr 18, 2013 08:24 PM
jsvec2000
Apr 1, 2011 10:30 AM
jsvec2000
Mar 31, 2011 04:17 PM
CigarCritic
Motorcycles For Sale
Aug 8, 2010 08:32 PM
