clack clack
Old Aug 1, 2013 | 03:13 PM
smithbrl's Avatar
smithbrl
I get clack clack almost every time I shut the motor off no matter if it's in gear, in neutral, in the garage or in the great outdoors. Sometimes if the bike didn't get run very far and didn't get really hot I don't hear it but that's rare. I think it's the compensator.
A year (15k) ago I had the same issue. I had changed the primary oil and found some rather large pieces of metal on the drain plug magnet. Before this the "fuzz" on the magnet was very small pieces so I brought the pieces I had found to the dealer. They said nothing to worry about.
Within a week the clack clack showed up so I brought it back and they wound up replacing the bad SE comp with another SE comp. So I'm thinking it's time to replace it again. I think I got about 25k out of the first SE comp.
After they replaced the comp the bike ran like new. It was smooth and no noises. When I shut the motor down it just stopped-no extra noises-no clack clack.
Seems like they could be beefed up a little bit or redesigned. Assuming of course, that it's a bad comp which I truely believe it is.
Old Aug 1, 2013 | 07:39 PM
rk10's Avatar
rk10
Didn't get a chance to ride it this evening ... doesn't clack clack as much till after I ride it and get it hot .... I appreciate the input .... figured somebody had to have this sound also ...
Old Aug 1, 2013 | 09:08 PM
GPHDXLC's Avatar
GPHDXLC
My 11, first year of the SE comp being stock, is starting to make this noise to at 21000 miles. Hot and in or out of neutral. Sounds a bit louder in the garage then out side but it's there. This Winter I think I'll have my Indy install a new one. I don't feel this is a big deal, as long as I'm right that it's the comp.
Old Aug 1, 2013 | 09:11 PM
Rootro's Avatar
Rootro
Your going to need to replace the Hemi Cam Torque Converter Relay switch.
Old Aug 2, 2013 | 10:51 PM
texaswiz's Avatar
texaswiz
Ya, I could not see any difference after I did that. I put it in upside down at first before I realized it. Maybe if I had used a 20/50 weight synthetic oil I would get better results. What is the best oil?
Old Aug 3, 2013 | 04:51 AM
rk10's Avatar
rk10
38 psi and your pipes are too loud .....
Old Aug 3, 2013 | 07:46 AM
VTL nut's Avatar
VTL nut
Harley is moving the way of (the old) Jeep now, and buying parts and using them from any manufacturer?
Time to go back to Honda if thats the case for the only thing I dislike more than Yamaha, is Mopar.
There is the accelerant, who has a match.........
Old Aug 3, 2013 | 07:51 AM
hardheaded's Avatar
hardheaded
mmmmmmm, synthetic oil
Deluxe Fatboy
Milwaukee Eight (M8)
27
May 22, 2017 04:55 AM
HDRK81
May 19, 2017 10:21 PM
PennysRockinB
Engine Mechanical Topics
Jul 8, 2016 10:45 AM
tjbennett
2014-2024 Touring Models
32
Oct 8, 2015 10:31 PM
baron3547
Oct 13, 2006 07:03 PM
