LED Light or Equalizer Issue
Old Aug 7, 2013 | 07:41 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default LED Light or Equalizer Issue
I've been running all LED lights for quite a while now without an issue. On my trip 2 weeks ago, my security key icon came on steady while moving and when I activated the turn signals, they blinked normal twice and then went to a fast blink. A check of the codes showed left & right turn signal faults.
Tried to reset my Biketronic Load Equalizer and when I push the right turn signal switch, a five digit code appeared in the speedo display. Each time I pushed the right turn signal, the next number moving left to right blinked.
Thinking it was a bad load equalizer, I contacted Biketronics and they sent me a new one. Plugged that in today and the same BS is happening.
Anybody run into this issue or have have any suggestions on where to start to look for a fix.
Old Aug 7, 2013 | 09:38 PM
Pioneer74's Avatar
Pioneer74
The five digits in the speedo display sounds like the way you enter a PIN to override the security in the instances you don't have your FOB on you. That sequence is initiated by pressing and holding both turn signals for 5 seconds.
If you are getting the display by pressing your right turn signal, it sounds like the issue might be with your left turn signal switch. Could be shorted or stuck closed.
cijs88
Jun 5, 2025 05:21 PM
livinlow
Electrical/Lighting/Alarm
Oct 24, 2016 12:38 PM
Rugged Racing
Jun 18, 2014 06:07 PM
04nightrain
Apr 4, 2011 11:15 PM
timestarved
Apr 24, 2010 08:02 AM
