2013 Street Glide 120 miles - Oil Pressure...
Old Aug 12, 2013 | 05:28 AM
BOSOXFan's Avatar
BOSOXFan
Default 2013 Street Glide 120 miles - Oil Pressure...
What is everyone oil pressure gauge say while it is running? Mine is at the pin by 60... this can't be right.
Old Aug 12, 2013 | 05:50 AM
richie's Avatar
richie
A brand new bike , not something the dealership checked before delivery to you .My Limited runs at 32,plus minus a couple depending on the outside temp, always has right from the beginning. Hopefully just a faulty gauge, but they need to check this out for you .
Old Aug 12, 2013 | 06:03 AM
BOSOXFan's Avatar
BOSOXFan
I should have mentioned this as well... Oil level is good, turn the bikes power on and it jumps from 0 to 60 with just the power on. then it stays the same even after its started up.
Old Aug 12, 2013 | 06:18 AM
geezer glide 56's Avatar
geezer glide 56
What is your fuel gauge registering?...I found those connections crossed on one from the motor co. not long ago.
Old Aug 12, 2013 | 06:24 AM
BOSOXFan's Avatar
BOSOXFan
Fuels gauge is accurate...
I am going to take it to the dealer but it might not be open this week. I am in Italy and everything closes this week for vacation. if not would you guys ride it? Like i said it is running fine and the oil level is where it should be. I am assuming it is a sensor or teh geauge itself since it heppens even when the motor is not running. Wondering if maybe a conection came loose....
Old Aug 12, 2013 | 06:27 AM
Drilln'Boss's Avatar
Drilln'Boss
Ride it.
Old Aug 12, 2013 | 06:56 AM
JustDennis's Avatar
JustDennis
Sounds like the gauge is bad. I had a bad voltmeter that acted the same way. WOuld peg as soon as you turned on the switch and stay there.
Old Aug 12, 2013 | 07:13 AM
my67pnycar's Avatar
my67pnycar
I would take it straight back
Old Aug 12, 2013 | 07:23 AM
geezer glide 56
My mistake the connection might be crossed with your volt meter...I would ride it...I think you have a crossed connection.
Old Aug 12, 2013 | 07:29 AM
BOSOXFan's Avatar
BOSOXFan
that might make sense, i noticed my volt meter moves alot depending on idol or throttle, and it is a brand new battery.
I am going to ride it to the dealer and hope they are open. if not i am going to keep an eye on it, enure the oil levels are good and ride. hell, most Harley's dont have an oil pressure gauge.
