Fork leaking, where to start
Old Aug 14, 2013 | 08:53 PM
DSmoke's Avatar
DSmoke
Default Fork leaking, where to start
Hi all, I have a 97 Ultra Classic and recently started to notice a problem with the front end. When I apply the brakes hard the front end dives and I hear a clank, or clunk, sorry I don't know how to best describe it. I put the bike on the lift and did some quick checks for the anything loose. I was going to replace the fork oil when I noticed the right fork is leaking from the top. Below is a picture. Where should I start? I looked at the service manual and it indicates to replace the banjo bolt with a new after removal. Would I need a new banjo bolt and washer? Should I just try to tighten it a little? The bike has 49K on it. I would appreciate any thoughts or help.
Old Aug 14, 2013 | 08:57 PM
mkguitar's Avatar
mkguitar
probably just ready for a complete overhaul- but you may buy some time by tightening the bolt a slight amount.
you can check for the exact area of the leak by cleaning the area, then spray with drugstore foot powder- the seep will wash away the powder at the source
it could be just the air fitting
if you decide on an end of season rebuild, a few of the guys have down some great work using the ricor system- read through some threads
https://www.hdforums.com/forum/touri...rk-better.html
mike
Old Aug 15, 2013 | 05:05 AM
DSmoke's Avatar
DSmoke
Thanks Mike. Yeah, I was hoping to make it through the season. This bike is a future bagger project, that will hopefully start this winter or early next spring. I have a cafe project to finish first, can't be without a bike. Once I get started on the project I will have the fairing off, and using the progressive drop kit in the front end. Plus a ton of other stuff so that's when I would like to rebuild.
I will give it a good cleaning and go for a ride to see whats up. I assume I can ride without the fairing cap since I only disconnected a few connectors.
Old Aug 15, 2013 | 09:21 AM
0ldhippie's Avatar
0ldhippie
Those air forks kind'a suck. Easy to switch but no sense if ya will be tearing into it all soon. If tightening the fitting doesn't work ya can just replace it with a plug. Then you'll be set when ya tear into it.
Old Aug 16, 2013 | 05:34 AM
DSmoke's Avatar
DSmoke
Cleaned it up, tightened the top bolt slightly and went for a ride. I was out for over an hour and checked for leaks when I got back. It was all dry except for on the air hose. I am not sure if I cleaned that or if it was new, so I will have to check that again. Even so, it was minor and I can probably make it through the season.
Shekinah5678
Sep 27, 2015 09:21 AM
BuckeyeUltra
Apr 14, 2014 02:52 PM
Skul5
Jun 25, 2013 07:05 PM
BostonIrish
Nov 12, 2012 08:41 AM
notlost_nc
Oct 15, 2008 05:01 PM
