Realistic oil drain interval?
Old Aug 21, 2013 | 04:23 PM
  #31
frog13's Avatar
frog13
Originally Posted by Oldskewl
You're suppose to change the oil?
Is it still "changing" the oil if I'm just moving it from the bike to the lawnmower? In the 70's I rode a shovelhead, drove an old mercury and had a Briggs and Stratton lawnmower. I ran straight 50w in the shovel for 3,000 miles, dumped it into the car for 3,000, then the mower until the next time I had more oil. Never had a problem with any of them ............ people spend too much time sweating the small stuff.
Old Aug 21, 2013 | 04:27 PM
  #32
beary's Avatar
beary
Do you still do that? What car gets your Harley oil?
Beary
Old Aug 21, 2013 | 04:47 PM
  #33
MADHOG's Avatar
MADHOG
Full Syn is expensive so why not get your money’s worth and just do it at the specified interval. Me personally; I like to change mine a little early (like around 4K) but that’s just me. I’m a bit of a stickler so I typically do things ahead of schedule.
Old Aug 21, 2013 | 04:58 PM
  #34
12hdrk's Avatar
12hdrk
Originally Posted by jeveretts
Wondering how long you guys are leaving your full synthetic in the crankcase.
I put Redline 20w-50 in my '07, and it has been 3200 miles now. Seems kind of early for a drain on a high quality syn.
Whatcha think?
4000-5000 or end of season. If only 2k by end of season it still gets replaced for winter storage as do the primary and trans.
Old Aug 21, 2013 | 04:59 PM
  #35
Punjabi Rider's Avatar
Punjabi Rider
5,000 motor Mobil1, 10,000 primary HD pimary fluid, and 20,000 Redline shock proof for transmission and on longer rides some time even 6to7K miles between changes bike has 80K miles no issue related to the oil otherwise plenty things went sour.
Old Aug 21, 2013 | 05:10 PM
  #36
SunCruise's Avatar
SunCruise
LOL...You don't have to. You can always add a quart every couple days and if there is more than enough the automatic leveler will blow any excess out the air cleaner.
Me... I use the scavenger and change somewhere between 3 and 5k (Amsoil)
SC
Old Aug 21, 2013 | 05:25 PM
  #37
Black King's Avatar
Black King
As far as change frequency compared to a Dino oil, the synthetic is the same. If the book says 5000 for Dino, same goes for synthetic. Synthetic doesn't last longer, it lasts better. Impurities from combustion still poison it the same as Dino, so change frequency stays the same. That's my plan anyway.
Old Aug 21, 2013 | 06:54 PM
  #38
mgmmgm's Avatar
mgmmgm
Default Scavenger
Originally Posted by TWIN CAM 96
I run mine to 5,000 & dump it but when I change it I use a Rogue Chopper Scavanger so I drain out all the dirty oil in stead of leaving dirty oil in the sump. Also replace filter at around 2,500 it's ownly $12.50
Yup-
I use the Scavenger, and wonder why all those with concerns about their oil and when to change it, do not consider what the Scavenger can do to prolong the life of the bike's engine.
Old Aug 21, 2013 | 07:04 PM
  #39
TUCCI's Avatar
TUCCI
Originally Posted by beary
Same reason some folks wax their bikes and some don't. Some store their bikes outside, some in the garage. some folks do their own maintenance, some folks pay mechanics. Some folks spend a lot of money customizing their bikes. Why, because it helps us feel better about our bikes. Simple really, we pay a lot of money for this hobby and how we dote over our bike is half the fun.
Beary
Amen Beary...........
Old Aug 21, 2013 | 07:07 PM
  #40
TUCCI's Avatar
TUCCI
Originally Posted by heritageblue2013
It's more about the filter. Run your redline to 5k, then get it analyzed. If its ok, next time run to 5k change filters then try another three then analyze. That's truly the way.
That's how the motor pool does it in the military....main reason I cant get my son to change his F____kin oil regularly....can't argue with a proven method like your describing above?
