shifter rod
Old Aug 22, 2013 | 06:49 PM
jgwoz's Avatar
jgwoz
Default shifter rod
I have 06 ultra. The front shifter has become a little sloppy so I am planning on replacing rod and front shift lever. I have gone thru the shop manual and dont see to much on that process. I do have an idea as to how it comes apart, but what I am asking is it good idea to apply some type of grease to the rod or should it be a dry fit ?
Thanks
Old Aug 22, 2013 | 06:52 PM
Redbeard719's Avatar
Redbeard719
I believe the older models had a Zerk fitting on the sleeve that is built into the outer primary cover. It's since been deleted.
When replacing the front shift shaft (I assume that's what you're replacing) I would apply a small amount of silver Anti-seize.
Old Aug 22, 2013 | 06:53 PM
mikeo33y's Avatar
mikeo33y
grease it and the shaft that the shift lever rides on. They have hardly any grease from the factory. i greased up mine and i could feel it shift smoother. Its shocking that Harley skimps out on grease in these areas although most bike companies skimp out on grease also. I use Bel ray water proof grease. stuff is awesome
Old Aug 22, 2013 | 06:57 PM
ses's Avatar
ses
I replaced mine with a shaft that has a grease zerk installed on the end. Now I can grease it when it needs it!
Old Aug 22, 2013 | 07:02 PM
ses's Avatar
ses
Do a search on Amazon for pingel greaseable shifter shaft.. This is a good replacement if you want to keep it lubed.
Old Aug 22, 2013 | 07:05 PM
JohnSWA's Avatar
JohnSWA
Piece of cake. Three hex pinch bolts and you're done. One for the back shifter (to get to the front shifter pinch bolt and one pinch bolt for the shifter shaft. Inspect the shaft spline for flats spots. It's a common problem and can be a real bummer on your ride to Sturgis! How do I know this??? LOL! Don't forget to use red locktite on the pinch bolts. Those babies can vibrate out too on your ride to Sturgis!
Old Aug 22, 2013 | 07:17 PM
jgwoz's Avatar
jgwoz
Thanks for the info guys. This will friday night project so I can ride with confidence on saturday.
Old Aug 22, 2013 | 07:44 PM
TWIN CAM 96's Avatar
TWIN CAM 96
If your talking about the shifter shaft the stock ends are junk I replaced mine with rod ends $20.00
www.rodendsupply.com
Old Aug 22, 2013 | 09:40 PM
TUCCI's Avatar
TUCCI
Where did you get that shaft from, got a link?
Old Aug 22, 2013 | 09:49 PM
TUCCI's Avatar
TUCCI
This the one you bought?
Amazon.com: INNER GREASABLE SHIFTER SHAFT, W/FITTING: Everything Else Amazon.com: INNER GREASABLE SHIFTER SHAFT, W/FITTING: Everything Else
Looks like the zerk is on the inside towards the engine, whats the clearance?
