shifter rod
Old May 3, 2014 | 09:15 PM
Veekness's Avatar
Veekness
Originally Posted by JohnSWA
Piece of cake. Three hex pinch bolts and you're done. One for the back shifter (to get to the front shifter pinch bolt and one pinch bolt for the shifter shaft. Inspect the shaft spline for flats spots. It's a common problem and can be a real bummer on your ride to Sturgis! How do I know this??? LOL! Don't forget to use red locktite on the pinch bolts. Those babies can vibrate out too on your ride to Sturgis!
Blue yes...Red no
Old May 3, 2014 | 10:54 PM
Tinman265's Avatar
Tinman265
Originally Posted by Tucker99
The one from Amazon is $24 and the one from Pingel is $85. Hmmmmm
The one from Pingel is stainless steel......
Old May 4, 2014 | 12:08 AM
skratch's Avatar
skratch
Originally Posted by wurk_truk
Best bet is go to store and buy a whole new shift rod. The stock ones S U C K ! I bought the cheap plain SE one, because it has the Heim joints instead of the crap stock.
nah, the shift rod itself is fine. but the rod ends do suck. i spent $8 and got a pair off ebay (seller name: racebasics), though it's been a couple of years.
Old May 4, 2014 | 01:16 AM
smithbrl's Avatar
smithbrl
Old thread, I know, but I was on a trip and one morning while I was inspecting the bike before leaving, I pulled on the heel/toe shifter and it slid right out, shift levers and shaft. The pinch bolt part of the shift arm that connects to the shift linkage had vibrated loose. I put some loctite on the bolt, realigned the shaft and tightened it down. All OK.
Old May 4, 2014 | 11:34 AM
0ldhippie's Avatar
0ldhippie
Since this came back to life, I'll do a little highjack: Anybody found Black powdercoated rod ends???
cwickgo9
Apr 19, 2017 12:55 PM
mkguitar
Dec 13, 2016 07:07 AM
Crashone
EVO
11
Jul 3, 2015 10:06 PM
jeremy2854
Jul 28, 2013 07:21 PM
dchoran
Oct 13, 2007 03:47 PM
