Derby Cover woes
Old Aug 23, 2013 | 06:36 PM
bagman1's Avatar
bagman1
leftcoaster and waltz hit the nail one the head. ALWAYS clean and chase pc or chromed holes, theres something about the process that buggers up the threads. Also absolutely make sure there is no pc on the inside where the oil is, it will break down and wipe out bearings or oil pump in the engine. Ask me why I spent another $1200 to fix a powder coaters F up. That **** is like sand when it breaks down.
Old Aug 23, 2013 | 06:42 PM
hdbob2006's Avatar
hdbob2006
Some bikes[or maybe all?] had a spacer,or thrust washer between the starter drive and the outer primary cover.[I don't remember seeing one on my '06,but I know my '02 Softail has one. I remember finding mine on the floor one time when I had a primary cover off. Check your shop manual,and see if your bike should have one.
Old Aug 23, 2013 | 06:57 PM
bagman1's Avatar
bagman1
There is a bushing in the outer primary cover that the jackshaft goes into when the drive engages, they may have removed the bushing when they pc'd it, and the pinion gear is walking out of the ring gear. I just installed a new starter on someones 03, just so you guys know on the starters prior to 07 style, the coupler between the starter and JS is no longer available. So dont loose it.
Old Aug 23, 2013 | 07:02 PM
Snakepit's Avatar
Snakepit
Make sure to only torque to 84-96 inch pounds(7-8 ft/lb). What causes these bolts to be hard to remove is actually the washers sticking to the primary and the bolt head. That is why they come out so easily if you have to drill the heads off.
Old Aug 23, 2013 | 08:38 PM
Rootro's Avatar
Rootro
Go get the correct screws and leave it alone before you end up having to buy a new inner and outer primary cover because you stripped all of the threads out. If you are struggling this much putting a couple of simple screws in, your in big trouble.
GOV5
2014-2024 Touring Models
40
Sep 23, 2023 07:03 AM
Kevin714
Mar 15, 2017 09:10 AM
Woofron
Jul 29, 2013 08:06 PM
dohadex
Mar 26, 2013 07:08 AM
beary
Aug 4, 2009 05:40 AM
