Not sure...
Old Aug 23, 2013 | 08:16 AM
bkgabby's Avatar
bkgabby
Default Not sure...
I recently did a stage 1 using the power vision tuner, FM header-AC-and pro touring pipes. I've noticed a rumble from the exhaust when i shift up through the gears as i use clutch...sounds like it does when i let off the gas getting ready to stop or down shift. I remember it being a little quieter during the actual shift process then pick back up again once in gear. Not sure if this is normal...I did just come from stock so no previous experience other than that.
Old Aug 23, 2013 | 09:57 AM
ndnguyd's Avatar
ndnguyd
What? You put free flowing exhaust on and have more sound...... Hmmmm..
Old Aug 23, 2013 | 04:31 PM
bkgabby's Avatar
bkgabby
whatever
Old Aug 23, 2013 | 05:25 PM
ftworthcowboy's Avatar
ftworthcowboy
By rumbling do you mean popping as in deceleration popping?
If I wind mine up I can get a pop between shifts, not every time though maybe just when I shift slower and the unburned gas in the pipe catches.
Old Aug 23, 2013 | 05:29 PM
bkgabby's Avatar
bkgabby
it's not popping,but it is the same sound it makes when decelerating. that sound is totally different than the cruising or getting on the throttle sound.
tom13
Mar 21, 2017 10:49 AM
crawrj
Oct 2, 2014 07:56 PM
StuxnetKiller
14
Oct 29, 2013 07:49 AM
Knights2TheEnd
Sep 2, 2012 02:39 PM
Rollon
Aug 5, 2009 04:06 AM
