From: Orig Surfers Paradise Australia, then Riyadh Saudi Arabia, Tokyo, Toronto, now So Cal
I had this exact issue on my PCV, if you go to the website (power commander.com) you will find this in the Support section:
Harley Touring Model
On my Harley Touring model once in a while my cruise control and 6th gear light will stop working.
If you experience any problems with cruise control, or 6th gear indicator light on a newer Harley Davidson Touring bike with a Power Commander V installed. In the Power Commander software go to Power Commander Tools/Configure/Harley ECM Data. Uncheck the box next to Diagnostic Port Enabled. Click OK. Click Send Map.
I also upgraded the firm wear at the same time. No issues since - simple fix!
