2014 Linked Braking System
Old Aug 30, 2013 | 07:59 AM
twistr's Avatar
twistr
Not a fan of linked brakes regardless of how old the technology is...there are circumstances for only using one of the brakes...
JMO, linked brakes are for the people who do not know how to apply proper braking skills...MOCO is trying to appeal to those people that think this technology is safer...BS if you ask me.
Old Aug 30, 2013 | 08:13 AM
Wally's Avatar
Wally
What would those circumstances be?
Old Aug 30, 2013 | 08:17 AM
Ovaltine Jenkins's Avatar
Ovaltine Jenkins
The only circumstance at the speeds where the brakes are linked would be trail braking while racing hot into a corner.
We don't have enough lean angle for that kind of racing.
Old Aug 30, 2013 | 08:18 AM
'05Train's Avatar
'05Train
When you gotta "lay 'er down" to avoid an accident...
I trail brake all the time, and as often as not, I use the front brake. Front or rear really doesn't matter much as long as you're doing it right. Bikes that do have the lean angle for that kind of racing also have linked brakes.
Old Aug 30, 2013 | 08:19 AM
Markk9's Avatar
Markk9
In the dirt...
Old Aug 30, 2013 | 08:21 AM
'05Train's Avatar
'05Train
Originally Posted by Markk9
In the dirt...
You planning on riding your 900 pound touring bike over 20mph in the dirt?
Old Aug 30, 2013 | 08:25 AM
RollaMo's Avatar
RollaMo
Originally Posted by '05Train
All the Touring bikes, except the RK have ABS standard, all ABS bikes have linked brakes.
The regular Street Glide does not have ABS brakes as standard equipment.
They are a $795 option on this model, just like the Road King.
The Street Glide Special has ABS as standard equipment.
Old Aug 30, 2013 | 08:28 AM
'05Train's Avatar
'05Train
I stand corrected.
Old Aug 30, 2013 | 08:35 AM
ChrisHo's Avatar
ChrisHo
Originally Posted by brettnbama
Yes.... The reflex brakes with ABS is part of the project Rushmore push. They are electronically linked rather than hydraulically linked. At speeds below 20 mph, the brakes de-link. It is exactly for the reason u cited. Don't want the front brake activating with the bars turned
Odd, in all the bikes I have owned with ABS, I rarely use the rear for anything. Are HDs that tippy? I don't own one yet, but it seems surprising how many fear their front brakes at low speeds.
Old Aug 30, 2013 | 08:39 AM
CRocks's Avatar
CRocks
I had a VTX1800T with hydraulically linked brakes, they worked GREAT! I was concerned because I live on a steep hill with 1000' gravel drive. At the bottom of the drive you need to do a 90 degree left turn + stop immediately for cross traffic. Normally, if you look at the front brake in those conditions you're on the ground. But, these worked perfectly + HD's electronic link should address that concern anyway. While not as good as ABS, it's a definite improvement over independent systems.
