CLUTCH CHATTER
Old Jan 18, 2016 | 10:40 AM
TriGeezer's Avatar
TriGeezer
Originally Posted by Guntoter
If fluid does not change it, then it most likely is glazed friction discs, probably from slipping the clutch too much or out of adjustment and it slipping. May need new discs and if the steel discs are discolored then those need replaced also.
Will these issues be apparent if pull the clutch pack?
Old Jan 18, 2016 | 10:48 AM
skid_pimp's Avatar
skid_pimp
Yes they will be
Old Jan 18, 2016 | 11:12 AM
Guntoter's Avatar
Guntoter
The steel plates being discolored, yes for sure. Little harder to tell on the friction discs but if discolored plates then discs need changed too. Frankly if you are going in that far I would change out the friction discs at minimum.
smokingjoe
Milwaukee Eight (M8)
17
Aug 22, 2017 11:37 AM
paulcorona1
Apr 30, 2014 09:03 AM
hunter1jonathan
Apr 21, 2013 10:36 AM
sporty06
Aug 14, 2007 02:51 PM
bobbsterkid7
Aug 2, 2007 02:01 PM
