ideas for upgrading 2004 flhci
Old Aug 31, 2013 | 09:27 AM
armycook's Avatar
armycook
Stage I
Default ideas for upgrading 2004 flhci
I am lookin gto do a litte upgrading on my 04 Road King Classic. being in the army and being married i have little money to work with so any cheep ideas would be greatly welcomed.
Old Aug 31, 2013 | 09:38 AM
mkguitar's Avatar
mkguitar
Thanks for your Service.
Welcome to the Forums
What is it you are interested in changing, looks, performance, handling?
There are all kinds of things which can be done, just remember that in performance there is a balancing act between cost, reliability and longevity.
You can control only 2, the third is determined for you:
"How Fast?
How Long?
How Much?
You get to choose 2"
Mike
Old Aug 31, 2013 | 10:34 AM
dawg's Avatar
dawg
When I had my 04 Electra I went 95" with HD piston kit, Andrews 26 cam, Ness Big Sucker A/C, SERT and V&H duals. I had started with only the A/C, duals and a Fuelpak.
Old Aug 31, 2013 | 02:15 PM
grbrown's Avatar
grbrown
Welcome to HDF from the UK. You have told us you don't have much to spend, but have asked a million dollar question! Give us a clue what sort of things you would like. We can do performance upgrades, a wonderful selection of technical upgrades, custom jobs, you name it!
Spend a little time browsing through HDF, as you will see members' bikes and also read about things you probably didn't know you can do!
Old Sep 1, 2013 | 05:50 PM
AlanStansbery's Avatar
AlanStansbery
I have an 04 RK Custom. I would look at reliability first. If you don't have the upgraded cam-spring tensioners, I'd get the HD upgrade. They used to sell a kit (probably still do) for about 450-500 bucks that had hydraulic tensioners, a new cam-plate, and a higher-volume oil pump in it. You'd also need adjustable push-rods (or to pull the heads, and use the 'stock' push rods), a new inner cam chain (don't reuse the one that's in there), and a new set of tappets (to do it right). While you're there, for another 3 or 4 hundred bucks (for parts) you could do cams, too.
When I did this kit, I bought a used S/E 203 set of cams off eBay for 50 bucks. They were inspected prior to installation, found to be fine, and have been in service with me now 30K+ miles. If you're not hinky about used cams, then this is one way to save some money on better performance.
My parts cost less than $900 (kit, cams, push-rods, cam-bearings, chain, tappets).
The cam-tensioner kit doesn't do anything for 1/4 mile times...but if you do this upgrade with cams, you'll notice a performance improvement.
If you can do the work yourself, you can save quite a bit of money. You'll need a couple of 'special' tools. But those can be borrowed/rented. Chances are you can get the base hobby shop to purchase them (for later use by others doing the same work). Though, maybe not (as budgets are tight). Worth a try.
The cam-tenisioners on our bikes (through 06) are a weak-point of the engine design. My attitude was it was best to get them out (they're spring-tensioned) and get the upgraded hydraulics in, i.e., the hydraulic kit emulates what the 07+ bikes have in this regard. And judging from the lack of complaints on the topic from the 07+ folks, it appears the HD modification (to hydraulics) works.
Thanks for your service.
Alan
Robert Resanovich
Feb 19, 2017 04:53 PM
Cobra1958
Welcome Area Only
18
Feb 3, 2014 11:12 PM
JBELCHER7876
May 8, 2013 10:27 AM
RedHammer
Welcome Area Only
25
Dec 17, 2006 11:03 PM
BigLeesFLHPI
May 2, 2006 01:49 AM
