Getting Trip Ready
Old Sep 10, 2013 | 02:43 PM
UltraNutZ's Avatar
UltraNutZ
man you guys are brutal.. LOL
Everything in the below 20k service list is easy to do and very economical if you do it yourself.
I agree 100% with grbrown in respect to NOT doing this the night before you leave.
20,000 Mile Service
20,000 Mile Maintenance (Will vary by model)
  1. Change engine oil and filter
  2. Inspect oil lines and brake system for leaks
  3. Inspect air cleaner and service as required
  4. Check tire pressure and inspect tread
  5. Check tightness of wheel spokes
  6. Replace transmission lubricant
  7. Check clutch adjustment
  8. Check primary chain adjustment
  9. Inspect rear belt and sprockets and adjust belt
  10. Check, adjust, and lube throttle, brake enrichener & clutch controls
  11. Inspect and lube jiffy stand
  12. Inspect fuel valve, lines, and fittings for leaks
  13. Check brake fluid levels and condition
  14. Inspect brake pads and discs for wear
  15. Check front brake lever pin
  16. Check brake caliper pins
  17. Check brake caliper boots and bushings
  18. Check rear master cylinder outer boot
  19. Replace spark plugs
  20. Check operation of electrical equipment and switches
  21. Check and adjust engine idle speed
  22. Replace front fork oil
  23. Adjust and lube steering head bearings
  24. Inspect shock absorbers
  25. Check tightness of critical fasteners
  26. Check engine mounts and stabilizer links
  27. Road test
Old Sep 10, 2013 | 02:45 PM
bigskyhd's Avatar
bigskyhd
You're going to definitely want to check those cam tensioners. Believe me, I know. I finally went with the hydraulic tensioners that HD put out a few years back. That year was famous for having them go south. It'll get awfully noisy on your trip next year if they do go......
2002HeritageMD
Southeast
Mar 16, 2020 12:22 PM
jerry a
Road Trips
Jul 8, 2013 04:39 PM
jeffsizemore
Road Trips
May 5, 2010 08:07 PM
mt76
Road Trips
Aug 15, 2009 09:35 AM
Mikey 1450
Road Trips
Jan 4, 2007 05:22 PM
