2003 Ultra trouble shoot question
Old Sep 9, 2013 | 05:23 AM
CSMHOG's Avatar
CSMHOG
Default 2003 Ultra trouble shoot question
Looking for help for a friend of mine experiencing bike problems up in the mountains on vacation.
He has a 2003 Ultra with rough running issues. He said it feels like an exhaust leak or vacuum problem but he doesn't hear anything different. He just had it serviced at a dealer before leaving on vacation for its 45,000 scheduled service. He's already pulled the plugs and everything looks normal. Any ideas what could be wrong. He says it's not bad gas, he's already burned through the tank of gas when the issue started and partly into another from a different gas station.
Appreciate any advice to pass along. Thanks in advance.
Old Sep 9, 2013 | 05:37 AM
pdzani's Avatar
pdzani
I would start with the intake manifold, you can have cracked o ring gaskets and never hear a leak. Spray some wd 40 around the intake manifold while bike is running and see if you have an rpm change, if so you are a step closer to finding the problem. Hope you can finish your mountain trip.
Old Sep 9, 2013 | 05:43 AM
CSMHOG's Avatar
CSMHOG
Thanks, giving it a try. I'll post the results.
Old Sep 9, 2013 | 08:29 AM
CSMHOG's Avatar
CSMHOG
Any others ideas? Symptoms continue ...
Old Sep 9, 2013 | 09:55 AM
CSMHOG's Avatar
CSMHOG
Ok ... In the interest of putting this issue to rest, problem solved by installing the correct spark plugs. Just another reason to do your own maintenance. Thanks for your input pdzani.
Old Sep 9, 2013 | 06:42 PM
dave anderson's Avatar
dave anderson
6r12's only
Old Sep 10, 2013 | 01:07 AM
T_Dogg80's Avatar
T_Dogg80
Thanks for coming back on here and telling us the solution. It will save someone the headache one day
Old Sep 10, 2013 | 05:38 AM
CSMHOG's Avatar
CSMHOG
Absolutely, that's what this forum is all about. It's saved me several headaches over the years!
hawg53
Aug 5, 2014 09:32 PM
lickalotapuss
Jun 22, 2012 03:18 PM
WNMORE
Jan 5, 2011 11:29 PM
BruceHarrisJr
EVO
Feb 5, 2008 01:27 PM
chippy
Jun 22, 2007 04:24 PM
