Fuel Moto 2-1-2 it just don't get any better.
Easy to tune right keeps your low end torque.
No header is magically going to make the heat go away it can help reduce some in the cat area.
Take-offs from a stock 09 FLH model... No cats and usually complete with original snake skins...
Put out a WTB order on the 09 headers and you will probably get many to choose from.
the budget solution is to have your header modded.
essentially that would be similar to my 09 header, which has no cat.
I have hi flow intake and exhaust and use XIEDS
Great to hear that I can swap headers and keep my XiED kit. Thanks.
Mike, was your '09 header catless from the factory or was surgery required? I wouldn't have the time or the tools to do the surgery myself, so my options would be limited here.
Don't overlook FullSac. They offer an exchange of your stock header that has been modified and ceramic coated, it's called the Sport Pipe. Cost is very reasonable compared to aftermarket headers and performance is right up there with the others.
Originally Posted by 0ldhippie
I just replaced the non-cat header on my '09 with a lightly used real Fullsack Xpipe... If I was paying new with only stage 1 their sportpipe would be serious contender.
I've heard good things about Fullsac, but I know ZERO about their Sport Pipe. I'll check them out. Thanks!
Hey, gliderman, does the Sport Pipe header retain the stock oxygen sensor bungs and are they located in the same positions as in the stock header?
