changes to HD LED headights
Old Sep 20, 2013 | 06:15 PM
Garemlin's Avatar
Garemlin
Originally Posted by mwegryn
That's the one. I'd like to see a side by side comparison at night. I like the looks of the new one better since it has a more traditional appearance when it's off. I also like the $100 price difference. Does it stick out like the Kuryakyn one requiring a different trim ring? If that's the case, I'm not sure it would work with the way the new fairing "brow" extends a bit over the top of the headlight.
This should help you out
UPDATE - LED Head Light Comparison JW/HD & TL
bonz:
Headlight:
67700173 for 13 and earlier
67700189 for 14 later
Passing lamps
68000075
Old Sep 20, 2013 | 06:19 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Originally Posted by Sheep
msg back from JW Speaker.
Dave,
Thank you for your inquiry. I am sorry, but this lamp is not designed to have the high and low beams on at the same time.
Thank you,
Tara Henke
I bet a simple wire mod would fix that.
With the lower amp pull of the LED lamps, should not be a problem.
Old Sep 20, 2013 | 06:25 PM
1st 96 ultra's Avatar
1st 96 ultra
But is that worth $200+???? , do you really need to ask after the money we spend
Old Sep 21, 2013 | 12:32 AM
hd_rolling's Avatar
hd_rolling
Sorry, hope I didn't confuse anyone. My pics are the truck light phase 7's, not the Harley version. I was just giving an example of what the new Harley lights look like.
Old Sep 21, 2013 | 06:42 AM
Jswerve's Avatar
Jswerve
Originally Posted by Garemlin
Save some money and get the Trucklite. It is the same thing branded for HD for over $200 more. You get a better warranty from Trucklite too. The only advantage I can see to getting the HD one is if you absolutely have to have that little light up bar and shield in the middle. But is that worth $200+????
I'm going to disagree with you. I saw many TL phase 7's and HD LED's and the HD were much more noticeable when coming at you then the Phase 7's. If that doesn't bother you then don't sweat it. I personally like the extra daytime visibility. I will be getting the JW version of the HD LED from Discount Fleet this winter. They run about 375.00
Old Sep 21, 2013 | 08:21 AM
Garemlin's Avatar
Garemlin
I am talking about the new HD LED headlight which is a rebranded or cloned Phase 7. Not the JW Speaker made Daymaker.
And as far as daytime visibility I run my Phase 7 on high beam during the day for better visibility. I am not viewing it from the front myself but I have seen them run on high beam during the day on other bikes passing by and they were very bright and visible. I will agree that the JWS Daymaker is a little more visible during the day because it has a slight blueish cast to it.
Old Sep 21, 2013 | 09:25 AM
mwegryn's Avatar
mwegryn
Thanks for the comparison. The phase 7 style does not seem quite as bright in the night time photos, unless it's just me.
Old Sep 21, 2013 | 01:01 PM
Jswerve's Avatar
Jswerve
Indeed sir, well said
Old Sep 21, 2013 | 02:42 PM
TheGrandPoohBah
Well said.
I am also a fan of the TLP7, but it does need to be on bright during the daytime for maximum visibility. I did the passing lamp wire mod to blaze all 3 on bright during the daytime.
IMHO.
Old Sep 21, 2013 | 02:51 PM
HDogg's Avatar
HDogg
I'm seriously considering the Trucklite but the only thing that's keeping me away is the way I was it sticks out.How much thicker is it?
