When to locktite?
Old Mar 7, 2007 | 04:18 PM
msbhvn's Avatar
msbhvn
Default When to locktite?
Is there a generalrule of thumb as to what should or should not receive locktite during assembly?
Old Mar 7, 2007 | 04:25 PM
Smitty0128's Avatar
Smitty0128
Default RE: When to locktite?
as i understand it is EVERYTHING gets blue
Engine parts get red.
Thats what i do now.
Old Mar 7, 2007 | 04:36 PM
gunrunner's Avatar
gunrunner
If its on a harley, every thing gets one kind or another, or you will be looking for a replacement.
Old Mar 7, 2007 | 04:41 PM
ace57's Avatar
ace57
From my thinking its more when not to locktite.
I just reinstalled tins, tank, calipers, axles, wheels etc....pretty much used the blue (243) on everything except axle nut, if I can recall.
I did use the red (271 I think) on the turn signal mount piece on my RK custom.
Seems like with the shaking I get on the 88A engine, I better not take any chances
ace57
'06 FLHRS "mattie"
Old Mar 7, 2007 | 04:43 PM
AtkRWC's Avatar
AtkRWC
If you have an EG, do not locktite the windshield bolts or the bolts joining the inner/outter fairings. You will pull the inserts out upon removal..Ask me how I know!
Old Mar 7, 2007 | 06:18 PM
ricaroo's Avatar
ricaroo
do you loctite the 2 bolts that hold the muffler (under the bag)
Old Mar 7, 2007 | 08:02 PM
Splatter's Avatar
Splatter
ORIGINAL: msbhvn
In general, any part that you'd be upset to see pass you on the highway should get locktite.
True story: when I was in the Army I was flying in a helicopter over the Texas desert when I heard a "ping" and looked in time to see a bolt bounce of the chopper's skid and fall to the desert floor. I got on the intercom and asked the instructor about it and he said in the serene tone that only flight instructors have, "Don't worry about it. They wire the important ones down."
Old Mar 7, 2007 | 08:17 PM
Gutman's Avatar
Gutman
Regular service items don't require loc-tite. If you choose use Blue. All engine fasteners typically use one dot of BLUE. RED is a thread locker and is used on Rotor bolts, Trans sprockets, Pulley Bolts, Compensator bolt/nut etc. Purple is used for any fastener witha low clamp load or bolts smaller than 1/4". Fuel pump top plate bolts. Green is a sleeve/bolt retainer, and is usually used in keyways. The biggest problem is people think if a dot will do, more is better. One small dot is sufficient. Most of HD's repalcement bolts have loc-patch. It is pressure sensative and bonds when threaded together.
Old Mar 7, 2007 | 09:28 PM
2wheeler's Avatar
2wheeler
Harley-Davidson sees fit to use locktite on the opposing-corner studs that secure the ECM to the electrical panel on the right side of the battery box. This causes the brass insert that is molded into the plastic electrical panel to spin in the plastic when you try to remove either of these mounting studs. Ask me how I know as well. I bought all new parts to replace and sure enough the brand new studs had thread sealer already on them. You may encounter this problem, as I did, if you are following the mounting instructions for a PCIII USB unit involving "cable tie" fixation. It's fine if you never need back in this location.
John Virginia
Old Mar 7, 2007 | 09:42 PM
Gutman's Avatar
Gutman
I know and you run into the same problem installing the siren kit. That and those fairing screws will stay tight in that brass insert. no loc
