Air shocks
Old Aug 25, 2005 | 11:46 PM
Mikeeeeeeeeee's Avatar
Mikeeeeeeeeee
"Moderator & Connoisseur of Ice Cream"
Default Air shocks
IS there a pump besides the HD one that will do the rear shocks?
Correct procedures for adjusting them?
Mikeeeeeeeeeeeeeeeee
Old Aug 26, 2005 | 12:28 AM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Air shocks
Mikeeeeeeeeeeeeeeeeeeee,
Progressive (I think) makes a pump just like the harley one. I don't know why you would want something different but your dealer should be able to find the progressive for you.
Check your air pressure and if it is too high you push the bleeder button until you get it where you want. I always add about 1-2 lbs of extra air prior to disconnecting the pump just in case you lose a pound or two.
Terry
Old Aug 26, 2005 | 07:15 PM
Big Ted's Avatar
Big Ted
My dealer carries both the progressive and the HD, and the HD pump was actually cheaper, so I went with it.
Old Aug 26, 2005 | 07:22 PM
Mikeeeeeeeeee
ORIGINAL: Big Ted
I stopped in today and picked up the HD one. Immediately checked my pressure and it was at 35, which is supposed to be the max.
Ted - youre a good size fella (like me). What do you set yours at for solo riding?
Mikeeeeeeeeeeeee
Old Aug 26, 2005 | 08:32 PM
Big Ted's Avatar
Big Ted
between 25psi and 30psi
Old Aug 30, 2005 | 12:26 AM
Bear64's Avatar
Bear64
Maxium air pressure is 35 lbs. on the rear and 25 on the front..I run 16-18 on the rear and about 4-6 on the front, it is a little soft but with my back injury I can still ride 400-600 mile days on it, and I weigh in about 250 lbs. he wallows a little in the curves but I have become used to it
Old Aug 30, 2005 | 03:27 AM
nmfxstc's Avatar
nmfxstc
I've run mine from 5 to 35 and find that with a resonable gear load (toll kit, cover, rain gear, shorty helmet, chaps, CDs, a couple fo towels, etc.) and two up, 15 on the rear (all I have...it's an '05) is perfect....and the shocks don't usually lose air.
Old Aug 30, 2005 | 11:45 AM
jlacasci's Avatar
jlacasci
I didn't even know there was an adjustment in the front on an Ultra? Where is it located? I'm at work so can't look at my maintenace manual the curiosity has got the best of me.
Joe
Old Aug 30, 2005 | 11:52 AM
pilot1996's Avatar
pilot1996
I've never played with the various levels...is less air softer? and more air harder of a ride? [&:] Seems obvious, now that I type it, but I'll let it stand to show my ignorance.
Mac
Old Aug 30, 2005 | 12:10 PM
Bear64's Avatar
Bear64
I have a FLHT not a Ultra, maybe you don't have a air adjustment on the front, but I do on mine, its right next to the one for the rear shocks, on the right side as you sit on it behind the saddle bag lidpretty easy to see.
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
