ultra heat problem
Old Mar 7, 2007 | 10:46 PM
sugarbear's Avatar
sugarbear
Default ultra heat problem
Got to ride the 07 ultra in 70 degree weather today. The heat off the right side was pretty uncomfortable. Has anyone come up with an aftermarket fix for this?
Old Mar 7, 2007 | 10:53 PM
ultra2006's Avatar
ultra2006
Default RE: ultra heat problem
yea put you some ture duals get rid of that cross over pipe and stage 1 with pc111 or sert.
Ram's Avatar
Ram
http://www.rjsoriginals.bizland.com/index.html
I've got them, work great and look good too.
Old Mar 7, 2007 | 10:56 PM
UltraKla$$ic's Avatar
UltraKla$$ic
I just turn on my air conditioner. Put it on high and enjoy!
or
TRY THESE
Old Mar 7, 2007 | 11:01 PM
dougbk's Avatar
dougbk
I will second the heat shields from www.rjsoriginals.com
Old Mar 7, 2007 | 11:35 PM
rdking330's Avatar
rdking330
Heat shields, I will be getting a pair even with true duels, specially in summer.
Old Mar 7, 2007 | 11:43 PM
choochoo's Avatar
choochoo
If you haven't had it done yet, and up to you if you want to.
HD is doing a voluntary adjustment, so called 0903 letter.
to remap the ecm for fue/ air mix and timing.
This will help it run cooler.
Or you could do as other suggested above
stage one download, SERT, PCiii (and others)
install heat shields www.rjsoriginals.com
turn on the a/c or perhaps relocate about 2 000 miles north west.
I hear outside temps there are a little cooler, that might help.
Old Mar 8, 2007 | 02:15 AM
brokenfingers's Avatar
brokenfingers
Duals definately take the heat from the right side... left side still gets warm, but its a ginormous improvement. For simplicity's sake, I just did a complete dual vance and hines setup with the ovals useing a fuel pak, 2K miles later and its working great. A bit louder and throatier but not so much you have to wipe the blood away from your ears from having to crank the volume to hear the stereo over them. Also going with a good synthetic oil will cool things down even further. Arguable the effectiveness of an oil cooler, but I put one on anyway as I just liked the look of the thing, and didn't figure it would hurt. Everytime I've checked the oil, my digital gauge says I'm right around 190 deg.
Old Mar 8, 2007 | 02:30 AM
mason417's Avatar
mason417
True Duals and the heat shield from kuryakyn will do the trick
pcmc2
Jul 22, 2019 11:40 AM
grubsie
Sep 14, 2018 07:32 AM
tcp
Jul 27, 2009 09:10 PM
kc10boom
Oct 13, 2008 02:46 PM
EagleArmsHBAR
Nov 8, 2007 12:44 PM
