apes on a 2014
Old Oct 2, 2013 | 08:42 PM
vegashd's Avatar
vegashd
Originally Posted by Bullbutch
Guy from Paul Yaffe called me and said that with his bars not the classics but the other ones for the street glide in the 12" and below do not require longer cables and wires.
Ya, but mounting 16s is an issue. Lol
Old Oct 30, 2013 | 08:15 PM
JC Childers's Avatar
JC Childers
1st Gear
I have a 2014 SG that I just put 14" Wild 1 bars on. No ABS. I bought my hydrolic clutch line, front brake line and lengthened the wires. The clutch and brake lines I got were the black braided (after market from Harley). It looks and feels great. I am 5'9" and it fits me great. Make sure your bars are 15" wide (on the inside to clear the dash).
Old Oct 30, 2013 | 08:30 PM
HDV-GLIDE's Avatar
HDV-GLIDE
12" risers are 12" risers.......Not saying it can't be done but it wont be pretty when your done.....
Old Oct 30, 2013 | 08:40 PM
lp's Avatar
lp
Yes, but don't forget some apes are wider than others. By inches sometimes... Wider apes take longer cables.
lp
Old Oct 30, 2013 | 08:42 PM
eviltwin69's Avatar
eviltwin69
I put 12.5" Wild 1's on my '14 Ultra. I went with +6 upper brake line and hydraulic clutch cable with 45 degree bango fittings. Did the same for my '12 SG. I had to buy the extentions for the switches on the '14 but you could probably get by with re-routing the wiring in the inner fairing. I just wanted to keep it nice and clean.
Old Oct 30, 2013 | 08:47 PM
G$'s Avatar
G$
From: LexVegas, KY...home of fast wimmen & beautiful horses
Get in touch with Johnny Vaughn at www.HDbikeparts.com. He's the cable guru. Hooked me up and solved the dilemma with my 16"s & CVO hydraulic clutch.
Old Oct 31, 2013 | 04:13 AM
BadX's Avatar
BadX
Just put a set of 12" Monkey Bars on my 14 SG. Was told by two sources that the stock length wires, brake and clutch lines would work with no problem. Well, had to add 6"s to the wires but the brake and clutch lines worked just fine.
Old Oct 31, 2013 | 11:55 AM
gotwages's Avatar
gotwages
I put those on my bike and didn't need to extend anything but the wires. They wouldn't be re-routed unless you ran them outside the bar rather than internally.
Old Oct 31, 2013 | 12:03 PM
WHOSNEXT's Avatar
WHOSNEXT
Originally Posted by gotwages
i put those on my bike and didn't need to extend anything but the wires. They wouldn't be re-routed unless you ran them outside the bar rather than internally.
do you have a picture?
levihd
Aug 19, 2012 07:34 PM
BloodbathFXDC
Aug 11, 2010 03:59 AM
DirtNap
Softail Parts
Mar 3, 2010 04:04 PM
huskers11
Mar 10, 2009 02:29 PM
molsen
Nov 17, 2007 05:18 PM
