Bagger wobble and HD Warranty.....
Old Oct 2, 2013 | 07:50 PM
TKDKurt's Avatar
TKDKurt
Sorry, OP, but it's on you. The post 2009 touring bikes don't wobble if they are properly maintained, and checking the tires regularly is your responsibility.
Old Oct 2, 2013 | 08:03 PM
skratch's Avatar
skratch
Originally Posted by dan conner
i think more people would check their air pressure on a regular basis if it was not so damned hard to do. it is a real pain in the *** to get a tire gauge on the valve stem that comes on these bikes--are you listening moco?
as an alternative to the 90* valve stems that anotherblacksg posted, i use an extension hose that i made from an old automotive cigarette lighter inflator. you know, the kind that has the nozzle that 'locks' onto the valve stem? what i did was cut the hose off, and in the end that was cut i inserted a schraeder valve. when i need to check my air pressure, i just lock the one end on the valve stem and use the schraeder valve for the air pressure gauge and tire chuck. makes life much easier, and it was a bunch cheaper than those 90* valve stems. not that there is anything wrong with them, i'm just a cheap bastard
Old Oct 2, 2013 | 08:06 PM
stro1965's Avatar
stro1965
BS. My '11 (same frame) is maintained religiously and has wobbled since day one.
Old Oct 2, 2013 | 08:21 PM
TKDKurt's Avatar
TKDKurt
BS back atcha. I've put over 25,000 miles on my '11 in all imaginable riding conditions, at all speeds, and no wobble. Although, if I all of a sudden forgot all of my riding skills I'm sure it theoretically might be able to wobble. Maintained properly and ridden skillfully they don't wobble.
Old Oct 2, 2013 | 08:38 PM
Ben221's Avatar
Ben221
What a bunch of douche bags on this forum. I don't want fricking free tires. I want the head shaking to stop. ****ing internet trolls can suck it
Old Oct 2, 2013 | 09:01 PM
lp's Avatar
lp
Don't let it get to you. Some are being unusually harsh and overly judgmental but hey it's the internet and since you are talking about the same bike most here have (frame wise) some figure you're talking about THEIR bike and get all emotional about it.
Judgmental asshats....You get used to it when you ride a Road Glide... Just Sayin
BTW, Keep air in your tires man. lol
lp
Old Oct 2, 2013 | 09:06 PM
Uncle Larry's Avatar
Uncle Larry
Bingo Brother ... Well said "TKDKurt" and regarding what "MKGuitar" said another Bingo Brother ... sooner or later you've got to be responsible for your own actions ... http://www.msf-usa.org/downloads/t-c...nchecklist.pdf
Old Oct 2, 2013 | 09:18 PM
Uncle Larry
From the guy who can't figure out how to air in his tires ??? Really???
Old Oct 2, 2013 | 09:48 PM
$tonecold's Avatar
$tonecold
Well if they do fix it I would be interested to know what was causing it. I have an '09 and I have never had the wobble problem. Doesn't mean that I will never have it or that anyone else that is having a problem with the wobble is full of BS. It is pretty well documented that some machines do have the problem.
Old Oct 2, 2013 | 09:55 PM
Casper's Avatar
Casper
Someone here posted about the wobble and stated he changed his rear swingarm bearings with teflon, sealed bearings and it cured to wobble....
search function?
