Bagger wobble and HD Warranty.....
Old Oct 3, 2013 | 08:14 AM
  #31
Bdad23's Avatar
Bdad23
It's how loose or tight the bearings are in the steering stem. There is a procedure to check it in the service manual. I was getting a little squirrelly in the curves
Old Oct 3, 2013 | 08:20 AM
  #32
crimson13's Avatar
crimson13
Originally Posted by motolocopat
What is Fall-Away?
It's a test done to check how tight or loose the neck bearings are.
Page 1-42 2013 service manual,"A steering head that is too tight can interfere with the vehicles ability to absorb a weave. A steering head that is to loose can interfere with the vehicles ability to absorb a wobble."
Old Oct 3, 2013 | 08:22 AM
  #33
offthewall's Avatar
offthewall
What is Fall-Away?
Old Oct 3, 2013 | 08:25 AM
  #34
VTL nut's Avatar
VTL nut
So weavles woble but they won't fall down?
Old Oct 3, 2013 | 08:49 AM
  #35
ColoFXDC's Avatar
ColoFXDC
It even states in the owners manual, if you lack common sense, that the rider must check tire pressure before every ride.
I'm not sure if you guys remember the infamous Ford Exploder recall when their tires were exploding.. It wasn't because of the tires.
It was because FMC couldn't get the exploder's ride height correct to reduce "roll-over" risk and it's rough-as-hell ride quality. So the great Ford engineering idea; keep tires to 25psi and put that on the door sticker. That lowered the ride height 0.375" and the ride quality improved.
However... Ford didn't take into account that the average motorist DOES NOT check tire pressure. So from 25psi, they would lose a normal rate of air and get to 15-10psi after a few months or so. So when the Exploder was loaded with people and luggage, the tires were grossly under inflated and they heated up, sidewalls succumbed to the load and blew out creating roll overs and fatalities.
All of which could have been circumvented by the consumer taking responsibility for his own vehicle; as stated in the owners manual to check tire pressure etc. So Firestone, even though they truly are shitty tires, got the bad rep from an engineering malfunction from Ford.
So if the front tire had 9psi in it, it must have been a bitch to maneuver in low speeds or to turn the handlebars while stopped.. (It's even in the Motorcycle permit written exam that a low front tire has higher steering effort).
So why would you want to put your life in the hands of a flat-rater at a ind. shop or a stealership? Low ride pressure on a motorcycle=Tire failures and crashes. I think the OP is now educated and won't make the mistake again, but you cannot forget "near misses" like that.
Old Oct 3, 2013 | 09:55 AM
  #36
skratch's Avatar
skratch
Originally Posted by offthewall
do not do this on your bagger. baggers have 'backwards' triple trees so the procedure is different. the quick down and dirty: jack the bike up so the front tire is off the ground. you might have to put something under the rear tire so that the front and rear are level. then turn your handlebars either full right or full left, and then let go. depending if you have a roadking, batwing or sharknose, the specs are different. but, if you get more swings than you are supposed to, then your neck bearings are too loose.
Old Oct 3, 2013 | 10:01 AM
  #37
AnotherBlackSG's Avatar
AnotherBlackSG
Originally Posted by Ben221
What a bunch of douche bags on this forum. I don't want fricking free tires. I want the head shaking to stop. ****ing internet trolls can suck it
HAH, it always gets me when someone comes on here, admits to doing something wrong, blames someone else for his problems, and then gets all butt-hurt when others call him on it.
Exactly! If a rider doesn't have the ability to recognize when a tire is essentially flat, then he has no business riding. He's just an accident waiting to happen.
Old Oct 3, 2013 | 01:00 PM
  #38
Ben221's Avatar
Ben221
Troll, I checked, you add nothing to this forum and your friends agree...log off.
Old Oct 3, 2013 | 01:11 PM
  #39
glasscannon's Avatar
glasscannon
my 2011 soft tail wobbled like a bitch before and after new neck bearings new tires ect ect etc....especially in that 50-40 decel area....i could never get that thing right
Old Oct 3, 2013 | 01:15 PM
  #40
AnotherBlackSG
So, you're not only butt-hurt by your own doing, but you've also just exposed yourself to be a liar. Well done - now there will be no reason to question your ignorance in the future.
Dude, it's a public forum. What did you expect? Considering that there are 10's of thousands of members, did you honestly think that everyone would share your sentiment and sympathize with your plight? It would be incredibly naive to think so. Chill out and grow a thicker skin before you have a heart attack.
Does that mean that you no longer have it and if not, is that the reason you got rid of it? Personally, if there was an inherent problem that wouldn't go away no matter what was done to it, I'd have to move on to a different bike.
