what is temp. difference ??
Old Oct 8, 2013 | 06:03 PM
JimmySG's Avatar
JimmySG
Default what is temp. difference ??
did the engine temp. drop once the cat was removed? if yes how much lower ? thanks
Old Oct 8, 2013 | 06:08 PM
my67pnycar's Avatar
my67pnycar
The engine temp is the same, the cat in the pipe is the problem. I installed a gutted cat I got from fleabay and the diff is night and day. My right leg is happier now. Do it and you wont regret it.
Old Oct 8, 2013 | 07:47 PM
1roadking's Avatar
1roadking
Changed my head pipe out to vance and hines power dual the temp difference on the right side is is amazing. Don't wait, get the cat out ASAP.
Old Oct 8, 2013 | 07:58 PM
Pine Tree's Avatar
Pine Tree
MODERATOR
Collected tuning data (including engine temp) both with and without cat...no difference in engine temp.
Old Oct 8, 2013 | 08:01 PM
JimmySG's Avatar
JimmySG
so will the rear cylinder still keep shutting off ?
Old Oct 8, 2013 | 08:23 PM
Uncle Paul's Avatar
Uncle Paul
That is what the V-IED is for.
Old Oct 8, 2013 | 08:30 PM
flight risk's Avatar
flight risk
the right thing to do.... I look forward to the results.
Old Oct 8, 2013 | 08:44 PM
JimmySG's Avatar
JimmySG
im up in the air, pc5 or v-ied ...not sure yet
Old Oct 8, 2013 | 08:48 PM
smitty901's Avatar
smitty901
No temp did not drop but that ball of heat right at the CAT may have improved.
remember how a CAT works it gets hot very hot to burn off pollutants .
Old Oct 8, 2013 | 09:26 PM
JimmySG's Avatar
JimmySG
"remember how a CAT works it gets hot very hot to burn off pollutants"
Thanks, that makes it very clear !
