what is temp. difference ??
Old Oct 8, 2013 | 09:37 PM
my67pnycar's Avatar
my67pnycar
Originally Posted by JimmySG
so will the rear cylinder still keep shutting off ?
Had my bike in a parade about a week ago representing my daughters girl scout troop in our county ( rode her on the back, she had a blast) my etims worked the entire time as it should. I have the gutted pipe, big sucker, xieds and klock werks super saver slip ons, complete stage 1 for less than 600 bucks, bike loves me for it now, hehe..
Old Oct 8, 2013 | 09:54 PM
Bushy's Avatar
Bushy
supposed to work at 1400 degrees.... hence Cat heat!!
Old Oct 8, 2013 | 10:46 PM
jammerx's Avatar
jammerx
I removed my cat pipe, installed a de catted pipe and re installed the pipe with the cat cause I was unhappy with the way it ran. No temp difference. The biggest difference in temps was handled with the Power Vision and Cams.
Old Oct 9, 2013 | 08:26 PM
JimmySG's Avatar
JimmySG
what cams did u use? andrews 57h ?
Old Oct 9, 2013 | 08:49 PM
ddm502001's Avatar
ddm502001
Just got a de-catted head pipe, in having worked on auto electronics with closed loop I will probably go to xieds to keep the system self educating and going closed loop at speed. The later model O2 sensors are wide range, heated and the processor is self calibrating(learns as you drive) as to needs for the engine so no remap need as instructed by a HD tech, the map will rewrite as you drive.
Techs take: swap head pipe to de-cat, run the ride on OE mufflers or the mufflers that had been on the bike for a few hundred miles(re-learn time). As the processor re-cals then add what exhaust you wish, just not open pipes like the old Boom Cans as the system needs some restriction or back pressure to let the O2 sensors work. The processor can adjust to single change variables as this over a short period of rides, it cannot adjust fast enough to do all at once or if a free flow intake installed same time and will drop fault codes if tried. Xieds after the mods will convert the 14.6:1 to 13.9:1 AFR and adjustable between by tricking the processor into seeing the data from the O2 sensors as a 14.6 ratio signal.
The tuners out there eliminate closed loop, you lose some timing, some fuel delivery adjustments for optimum ride economy and you actually lose some engine performance that has to be redialed as a map. Not my personal choice.
Old Oct 11, 2013 | 09:49 PM
JimmySG's Avatar
JimmySG
ive had v & H monster rounds on for 2k miles. Just installed de-catted head pipe.
Old Oct 11, 2013 | 10:06 PM
94ruck's Avatar
94ruck
My ryobi heat gun showed 40 degrees difference at the 02 bung on the cat header over the same location on the vh power duals.
I noticed that the pipe cools down faster when shut off as well.
Holding that 40 degrees higher temp in the exhaust created a very warm mass of metal around the exhaust and tranny cover that the rider and passenger felt.
Nothing externally on the motorcycle got near 1400 degrees..
i have a decatted header if anyone is looking for one.
Old Oct 28, 2013 | 09:12 PM
JimmySG's Avatar
JimmySG
it seems that parade duty comes on even when its cool out. does the computer sense being in traffic ?
Old Oct 28, 2013 | 10:59 PM
texaswiz's Avatar
texaswiz
How do the manufacturers of de catted pipes get around the fact that not having a catalytic converter on a late model bike would clearly be in violation of Federal EPA laws. Evidently not many states check for catalytic convertors on motorcycles either. I have heard from several people that advised to stay the hell out of Denver, Colorado if you were passing through there with anything but stock OEM mufflers. Apparently the cops all have decibel meters and are only too eager to pay for them by nailing unsuspecting out of state riders.
Old Oct 28, 2013 | 11:25 PM
ke5rbd's Avatar
ke5rbd
did the engine temp. drop once the cat was removed? if yes how much lower ? thanks
I ride some with a friend that has a 2008 UC and I have 2010 FLHTK. He has the S&S 2-1-2 head pipe no cat and I have the stock headpipe on mine. Both have 4 inch slip ons and are using Power Vision mounted and monitor the temp. In the cool air we both are running around 215° when in heat they get to around 230° and 250° in town. They are usually within 2 to 10 degrees of each other. I would say the only temp difference will be in the area of the cat.
rsking45
Engine Mechanical Topics
May 30, 2023 11:40 AM
adm
Apr 20, 2016 11:49 PM
Louie-lou
Apr 16, 2016 02:44 PM
hemi1300
Jun 13, 2015 11:30 AM
Yo Nadz
Jun 20, 2014 10:32 PM
