Vibrations
Old Oct 10, 2013 | 06:10 PM
oc1014's Avatar
oc1014
Default Vibrations
Will opening up the ends of stock 103 baffles cause vibrations felt by the passenger. I'm trying to locate the source which she says is most noticeable at 55mph. It's a 13 Eglide Ultra with 8,000 miles.
Old Oct 10, 2013 | 06:31 PM
SBates08's Avatar
SBates08
Anything is possible. Could be that now at that speed and particular rpm the muffler starts to resonate which could in turn cause a vibration.
Old Oct 10, 2013 | 07:30 PM
mkguitar's Avatar
mkguitar
try to isolate whether the vibes are road speed or motor speed related.
if you are running 55 mph in 6th gear, that is the bottom end of the motor wanting to fall out on the pavement, 2100 rpms is too low a motor speed for that load.
you can isolate by hitting 55 mph and pulling in the clutch and dropping revs (or reving higher)..any change?
you can try a different gear
or you can find the rpm range that bothers her, and try that same range in different gears
make sure that the exhaust is not contacting the frame at any point
mike
Old Oct 11, 2013 | 05:50 AM
grbrown's Avatar
grbrown
Your bike will happily run at 55mph in 4th, 5th and 6th gears, so do as Mike suggests and see if changing gear changes what happens. Report back!
chillishovel
Shovelhead
Aug 19, 2015 12:48 PM
djl
Jul 31, 2014 07:58 AM
ultrarex09
Sep 23, 2013 07:44 AM
Corndog
Jul 18, 2011 12:28 PM
bullwinkle
Apr 19, 2008 07:55 AM
