Shutter,Buffet,vibration problem ?
Old Apr 18, 2008 | 09:20 PM
bullwinkle's Avatar
bullwinkle
4th Gear
Default Shutter,Buffet,vibration problem ?
Suggestions please.At 40mph in 4th gear there appears to be a vibration.When I pull in the clutch it goes away.In 3rd gear,higher rpm, no vibration.Being fairly new to H-D, is this just normal vibration or could there be a problem with transmission,engine or what? 2005 flhrci 4000 miles.
Old Apr 18, 2008 | 09:30 PM
rysess20's Avatar
rysess20
Default RE: Shutter,Buffet,vibration problem ?
Prob normal, the lower the rpm and the higher the gear you will notice more of a vibration at slower speeds. You'll prob notice some vibrations through the handle bars as your slowing down and downshifting at a low rpm. My vote is normal because what your describing sounds like mine and this is my first harley too.
Ryan
Old Apr 18, 2008 | 09:36 PM
cowboyglide's Avatar
cowboyglide
By shuttering and the vibrations your engine is telling you that you are lugging it in 4th gear at 40mph. You should be in 3rd. You even stated that in 3rd gear, at a higher rpm there is no vibration.
You will get the shuttering and vibration in any gear where your speed and rpm are to low for that particular gear. Lugging is the worst thing you can do to a harley motor. Higher rpms will not hurt your motor.
ORIGINAL: bullwinkle
Old Apr 18, 2008 | 09:38 PM
MDodson's Avatar
MDodson
Above 2500 rpms in any gear will solve the shuttering problem. You are lugging it.
Old Apr 18, 2008 | 10:15 PM
Stretchman's Avatar
Stretchman
Try 15-25-35-45 for shift points. The bike will smooth out somewhat if you have the stage one done.
Old Apr 19, 2008 | 07:55 AM
bullwinkle's Avatar
bullwinkle
4th Gear
Thank you all for replying.Makes me feel a whole lot better.Great to know of the support out there if one has a question.
ultrarex09
Sep 23, 2013 07:44 AM
greenvarmit
Jul 26, 2012 05:20 PM
Dancemax
May 7, 2009 08:15 AM
TimDynaBob
Jul 21, 2007 08:42 AM
gilmour68
Oct 24, 2006 08:30 PM
