Vibration while pulling in 5th/6th
Old Apr 12, 2010 | 06:53 PM
greenvarmit's Avatar
greenvarmit
Default Vibration while pulling in 5th/6th
So I don't feel the vibration in any other gears, only 5th and 6th gears and it's while pulling, example, cruising at 55mph in 5th and roll on the throttle or 6th at about 65 mph and roll on the throttle i get a strong vibration in the pegs up to the seat and in the bars. I know what your thinking, of course there's some vibrations but this in new, I've never noticed it and it's only in 5th and 6th gear. It almost feels like there's a loss of power too?
Anyone else experiencing this type of problem before?
Old Apr 12, 2010 | 06:59 PM
JimmysFXDC's Avatar
JimmysFXDC
Sounds like you're bogging the engine, try down shifting.
Old Apr 12, 2010 | 07:32 PM
greenvarmit
Oh come on......Seriously? I've been riding for a while, and the vibrations only started recently. The book even recommends shifting to 6th at 55mph so why would HD recommend shifting from 4th to 5th at 45 and 5th to 6th at 55 if it's going to bog it down?
Old Apr 12, 2010 | 07:39 PM
JimmysFXDC's Avatar
JimmysFXDC
WOW! Don't get your panties in a bunch! There was nothing in your post about how many miles on the bike, what year it is and with a low post count it's easy to assume that you don't know much about the bike. So, I do appologize for my assumption.
Old Apr 12, 2010 | 07:49 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Does your owners manual recommend those shift points or the salesman? From your explanations, it sounds like you lugging the engine. Too high a gear for the low speed, looking for that "Harley sound". If the bike is still under warranty ask the dealer to reflash your program, maybe the ECM lost a map or two. Most people I've talk to won't shift to 6th till 65 or 70 mph.
Old Apr 12, 2010 | 08:01 PM
greenvarmit
I didn't mean for my reply to sound that pissy, so I appologize to you. The bike is 09 street bob with around 7000 miles, and like I said in the original post it has started doing this recently.
Yes it's the Dyna owners manual......and the dealers here in Virginia Beach won't says the warranty is voided due to the Vance and Hines pipes that the dealer in NY where I bought the bike had installed. How's that for service?
Old Apr 12, 2010 | 11:38 PM
archergodwin's Avatar
archergodwin
They are full of ****. The dealer has to prove that the pipes did something to void the warranty. Find your sales sheet, and then contact the Motor Company. Some f*cking dealers... I swear.
Anyway, it is pretty much consensus that the manual is at least 5mph off for designating shift points. However, things to think/check:
1. Temperature when you were riding. If it's colder than normal, you'll get more vibrations.
2. Check your front motor mount.
3. Anything changed or serviced in the last couple hundred miles?
Old Apr 13, 2010 | 12:29 AM
JaronB's Avatar
JaronB
I got a little more vibes this year as well. I got just about 7k on my bike and like Archer said the colder it is the more vibes. When it's hot outside my bike will cruise in 6th going 60 no problem. I went out yesterday for about 75 miles and it was 56 degrees and it did not like 6th, so I just romped around in 5th. I still have a little more vibes then I remember from last ride season. This weekend I'm going to do a vehicle alignment and shim the front motor mount and see how that does.
Old Apr 13, 2010 | 03:38 AM
joe.1955's Avatar
joe.1955
My bike developed a "shudder" type vibration at cruising speeds ('08 Wide Glide).
Normally I hit 6th gear at about 70 mph, when the shudder started I couldn't use 6th gear below 85 mph because of the vibration. If I was riding 2 up, I couldn't use 6th gear at all.
It seemed to be related to low rpm / high torque situations, like cruising on the freeway. It actually felt like I was lugging the engine when I knew I wasn't.
I took it to the dealer and they couldn't find anything wrong. I was convinced it was a weak compensator spring pack allowing the torque pulses through that it was supposed to absorb.
The dealer had no way to test the condition of the compensator pack other than to shake it and listen for the rattle of a broken spring. I paid $250 for the SE compensator pack, which is built much stronger (and heavier) than the stock compensator, and had them install it.
That took care of the problem on mine. I can once again ride 2 up at 70 mph with no problems.
Not saying that's the problem with yours, but it might be something to look at if you can't find any other causes.
Old Apr 13, 2010 | 09:24 AM
JaronB's Avatar
JaronB
Joe!!
I hope that's not the problem with mine, but how many miles did you have on your bike when you installed the SE compensator?? What you described is exactly how mine feels and in the same situation.
Thanks!
