degreasing engine
Old Oct 12, 2013 | 09:03 AM
jus2anoyu's Avatar
jus2anoyu
Use a specific degreaser. It's basically kerosene in a spray can. It will not damage your engine paint as alkaline cleaners can.
I have a Allen wrench that has about 1/4 cut off the short end for intake bolts. I've tried most everything else, and this seems to work the best. It's slow, but it works.
Old Oct 12, 2013 | 03:14 PM
christo651's Avatar
christo651
How do you torque it with out being able to get a socket on it?
Old Oct 12, 2013 | 03:36 PM
Shovelhed's Avatar
Shovelhed
Change the bolts so it's not Allen head when you put it back.
Old Oct 12, 2013 | 04:02 PM
hog95023's Avatar
hog95023
I was told to use brake cleaner or simple green on a cold engine and wash off.
Old Oct 12, 2013 | 04:57 PM
Imold's Avatar
Imold
Originally Posted by just plain john
There's a youtube vid from S&S where they're doing a big bore kit. In it, they mention a specific tool used to remove/reinstall the intale manifold bolts. It's a long allen wrench with a ball end. It's an old adage, but use the proper tool for the job.
I use a ball end Allen wrench, works fine. So far...
Old Oct 12, 2013 | 07:38 PM
jus2anoyu's Avatar
jus2anoyu
By knowing what the correct torque feels like. After you've torqued a million + bolts in your life as I have, you get a feel for it. Yes, the ball end Allen wrench will work once you break them loose. A ball end Allen has a tendency to wallow out a Allen bolt if you try to break it loose from tight.
Old Oct 12, 2013 | 07:39 PM
jus2anoyu's Avatar
jus2anoyu
I've done that as well, it's not significantly easier when it's time to get a wrench on them.
Huggerbugger
Jun 10, 2017 05:57 AM
Memo7070
May 17, 2015 08:27 AM
brwdarr
EVO
Feb 24, 2010 07:45 AM
KustimKool
Exhaust System Topics
Sep 19, 2007 05:20 PM
mershon
Oil Archive (no new posts)
13
Jul 21, 2007 10:18 PM
