Engine rough on throttling
Old Oct 13, 2013 | 08:33 AM
ral819's Avatar
ral819
Default Engine rough on throttling
I just started noticing that if I rev the engine there is a momentary rough spot initially, then the engine seems to catch up. This just started happening. Twisting the throttle normal, no problems, but when I twist it fast, there is a momentary rough spot until the engine catches up. Does the cooler air temps play into this requiring a tuning adjustment ?
Old Oct 13, 2013 | 09:22 AM
The Dude's Avatar
The Dude
This may not be it but you may want to check this thread. I found my vac cap off and after posting I found a couple people local missing theirs, mostly all 2012 bikes. Mine is a lot smoother but I also was installing a stage 1 when I found it.
https://www.hdforums.com/forum/touri...t-this-is.html
Old Oct 13, 2013 | 10:03 AM
ral819's Avatar
ral819
I definitely have the open tube like your link shows. I can't find the fix though. Was there a tube or a cap for that ?
Old Oct 14, 2013 | 04:28 AM
ral819's Avatar
ral819
I found a pack of Vacuum line caps at the local O'Reillys . For 2.99 they have a pack with multiple sizes. The one issue I noted was how bad the engine ran after capping off the purge tube. I figured that the ECM needed time to recalibrate to having that Purge Tube capped off again. My Indy told me it needed to be capped as well. I rode the bike and in about 20 miles or so it started to run normally. I also looked at a few Streetglides when I stopped at some watering holes. I noticed they all were capped. Another lesson learned...
donmontalvo
13
Nov 20, 2018 04:20 PM
VDeuce
Milwaukee Eight (M8)
Feb 26, 2018 02:31 PM
sphoad
Jul 8, 2009 05:50 PM
cglofland
Apr 30, 2008 07:26 PM
RoadKing52
Oct 26, 2006 12:29 AM
