Lifter noise????
Old Oct 14, 2013 | 04:43 PM
rockybs's Avatar
rockybs
6th Gear
Default Lifter noise????
I have a 2006 FLHTCUI - Big Bore. I have had 2 sets of lifters installed. After about 500 - 1000 miles I get what sounds to be lifter noise (very loud). It sometimes will last for a couple of miles. Have had it apart 3 times. The first set of lifters were Woods and the second set are Adams. Any suggestions on what to check next?
Old Oct 14, 2013 | 10:10 PM
$tonecold's Avatar
$tonecold
As you have an early model TwinCam with the spring tensioners I'm not sure what to tell you. Much of what is discerned as lifter noise is actually chain noise and noise in other areas of the valve train. I have an '09 and after many attempts and hundreds of $$$ I have finally quieted my valve train. If by some chance you want to upgrade to the hydraulic tensioners be sure to get the Zippers dual piston tensioners, Axtell's oil by-pass system, and if you really think the lifters are at fault, Gaterman lifters. If you don't want to spend hundreds of $$$ to do that, at least try the Axtell oil by pass system. It's less than $100 and it may help. Not guaranteed, at least by me, but it may.
Old Oct 14, 2013 | 11:14 PM
slick813's Avatar
slick813
the Axtell bypass quieted my 2010 CVO Ultra down quite a bit.
Old Oct 15, 2013 | 12:23 AM
Def Mute's Avatar
Def Mute
Or, for only $12.95...
http://www.baisley.com/oil_spring_product.htm
Not as fancy as the Axtell system, but worked for me...
Old Oct 15, 2013 | 12:46 AM
2AMGuy's Avatar
2AMGuy
Community Influencer
I've got a '13 CVO S/E Ultra.
I can accept the constant "ticking" of the tappets but I occasionally get a heavier sound at about 2800 RPM's with the engine at light to medium acceleration, doesn't seem to do it under hard acceleration.
Also, during a climb in the Smokey Mountains this summer, the engine got a little warm (not really hot) and one lifter or tappet was a bit of a concern but once the bike sat overnight the noise went away the following day.
I'm getting close to the 10,000 mile check up (may be next spring) but I'm thinking this will be a problem that needs addressing.
Many years ago, I bought a new '75 Electra Glide (Shovelhead) that had a persistent lifter "clack" and it turned about to be a sloppily built engine that required a total upper end re-build to get it right.
Old Oct 15, 2013 | 07:21 AM
rockybs's Avatar
rockybs
6th Gear
Thanks for all the replies, I will look into these. I have the hydraulic tensioners and had the engine rebuilt 2 1/2 years ago. Issues started in May when we were in the Branson MO area and continued when in the Rockies. $$$$ later, new lifters, and I still have a noise. Will definitely check into the Axtell oil bypass system.
Old Oct 15, 2013 | 07:34 AM
fwb35's Avatar
fwb35
When my cams were done I put in Comp Cams V Thunder lifters, bike is very quiet now
Old Oct 15, 2013 | 11:12 AM
rockybs's Avatar
rockybs
6th Gear
Thanks Every time we play around with the lifters the noise goes away for 500 to 1000 miles and then comes back. it is almost to a knocking sound.
HDJaco
Engine Mechanical Topics
Apr 28, 2016 07:38 AM
mang0
Sep 11, 2012 09:19 PM
nemick
Jul 6, 2010 09:35 AM
TedMan
Exhaust System Topics
40
Apr 16, 2010 01:12 PM
97classic
EVO
Jul 14, 2009 02:17 PM
