Replacing Gauge lights
Old Oct 16, 2013 | 03:40 PM
Terrabella's Avatar
Terrabella
Default Replacing Gauge lights
My lower left gauge light is out on my instrument panel. I pull the bat wing outer shield but cannot get to the instrument without unplugging a bunch of wiring and major removal of other items. Can I pull the gauge out from the front of the panal to get at replacing the light bulb?
Old Oct 16, 2013 | 03:44 PM
ponch3640's Avatar
ponch3640
I believe you have two nuts holding the gauge in place. You can get the light out it's just a pia to get to
Old Oct 16, 2013 | 03:50 PM
TMOUT's Avatar
TMOUT
Try a set of long reach needle nose pliers, worked like a charm for me.
Old Oct 16, 2013 | 03:59 PM
Pelonz's Avatar
Pelonz
Yes the gauge comes out from the front but it is secured from the rear. Just do what he ^^ said and you won't have to remove the gauge. BTW all the gauges are the same configuration so you can practice pulling the bulb from a gauge that is easier to get to.
Old Oct 16, 2013 | 05:40 PM
fat daddy's Avatar
fat daddy
Long nose needle nose pliars works like a charm
Old Oct 17, 2013 | 08:56 AM
Terrabella's Avatar
Terrabella
Default Pliers did the trick.
Thanks...that worked. Still don't get why HD uses those orange condoms on the lights...why not just put in colored bulbs or LED in the first place? Anyway, thanks for the help.
BadBilly49
Apr 27, 2014 08:20 PM
Lilman
Jun 26, 2010 06:25 PM
Road Hawg
Feb 12, 2009 08:08 AM
vzts4q
Dec 6, 2008 11:16 AM
JLHOG
Jan 31, 2008 05:02 PM
