Tip for Replacing Header
Old Oct 17, 2013 | 05:15 PM
Mike flhp's Avatar
Mike flhp
Default Tips for Replacing Header?
Didn't find a lot searching posts (maybe a good thing), so figured I'd ask if any do's, dont's or tips. 2011 RK (103) replacing stock with decat pipe, and 4" Jackpots. Got new gaskets, clamps, etc....better safe than sorry for a few bucks. Have HD manual....seems too straight forward. Thanks in advance!
Old Oct 17, 2013 | 05:16 PM
blazink5's Avatar
blazink5
Pretty much straight forward. Don't forget to use copper anti seize for your O2 sensors.
Re-torque after heat cycle.
Old Oct 17, 2013 | 05:18 PM
davidwruth's Avatar
davidwruth
Tighten pipes evenly
Old Oct 17, 2013 | 05:25 PM
chester1957's Avatar
chester1957
Watch that the front exhaust flange doesn't slide down while you are wrangling the pipes off and scratch the nosecone. I zip tie the flange up, so I don't have to mess with it.
Old Oct 17, 2013 | 05:34 PM
Pioneer74's Avatar
Pioneer74
Is the de-catted pipe a stock pipe or an aftermarket one?
Use a torque wrench! If not, you may snap the studs off the heads!
Stick to the manual tightening sequence and you should be fine. Don't forget to re-torque after 5 or 6 heat cycles.
Old Oct 17, 2013 | 06:45 PM
Mike flhp's Avatar
Mike flhp
Its a stock off ebay (bobvic2 or vicbob2....recommended here). Window method...looks good.
Old Oct 18, 2013 | 01:15 PM
Mike flhp's Avatar
Mike flhp
TTT. Doing the change tomorrow....just dont want to screw something up. Tx!
Old Oct 18, 2013 | 01:26 PM
Grillfish's Avatar
Grillfish
Exhaust stud tq is in INCH lbs not ft lbs. Follow the tq procedure in the manual.
If replacing the exhaust gaskets, put them in the freezer before you start the project, should help sliding them in.
Old Oct 18, 2013 | 02:40 PM
madmustang4's Avatar
madmustang4
I put the crush gaskets in the freezer and let them freeze. Makes it a little easier to put in.
Old Oct 18, 2013 | 02:45 PM
DDuess's Avatar
DDuess
Look up the new torque spec for the transmission trap door. The bolts that hold the pipe mount at the transmission are famous for loosening and causing a trans oil leak at the trap door. Re torque them to the new spec now rather then later. The spec went from 18 up to 25 foot -lbs, reference service bulletin m-1305. It is hard to get to the bolts with the header pipe installed. When I put on my Jackpot header I checked the bolts tight at the old spec, and they still loosened and leaked. No problems so far after the re torque.
