Bar change advice needed
Old Oct 19, 2013 | 10:46 AM
ridedaddy's Avatar
ridedaddy
Default Bar change advice needed
I'm looking to go to a 10" mini ape. I'm trying
To decide between monkey bars, prime apes or wild 1 chubby bars. Seems like the la chopper bars are quite a bit wider than the others? What cable or wires will I need to extend for my 2013 SG? any opinions on these bars?
Old Oct 19, 2013 | 12:42 PM
Pelonz's Avatar
Pelonz
A lot of threads in here on this subject. Use the search field. Chucky can tell you exactly what you need to the bars you choose.
Old Oct 19, 2013 | 07:59 PM
HD Jim's Avatar
HD Jim
If you are going 10", then the only cable you might have to change is your clutch cable
Old Oct 19, 2013 | 10:33 PM
RootbeerKing's Avatar
RootbeerKing
Wild 1's on my 09 RKC...no cable changes but did add the extenders to the TBW
Old Oct 19, 2013 | 11:16 PM
blackswampbiker's Avatar
blackswampbiker
I went with Prime Apes (13" so cant help with they cable question) they are wider then the MBB which is one reason I went with them I think they look meaner another they are made here in the good ol U.S.A. unlike the MBB bars
Attached Thumbnails Bar change advice needed-imag0197.jpg   Bar change advice needed-imag0195.jpg
Old Oct 20, 2013 | 02:34 AM
Sc0-'s Avatar
Sc0-
10" WO-575's here.
Installed with all OEM components and rerouted the clutch cable, after a few thousand miles I went with a longer clutch cable and ran it through the fairing like OEM. The wires were ran inside the bar tubes, no problems and no extenders are required.
These bars are 100% improvement over stock, but after a long ride I noticed that the outer parts of my palm were hurting due to the grip angle of the bars. I am now looking at 12" bars with less grip angle, I believe the 575's are 42 degree.
Old Oct 20, 2013 | 06:45 AM
mrsnipy's Avatar
mrsnipy
Ive been following this tread, i have been thinking of apes also..are the 10 inch really higher than stock? local dealer said stock bars have a 10 inch rise already and mine feel low causing shoulder pain...i have heritage bars on my road king but they wont fit on my ultra
vahalla
Feb 22, 2017 06:10 PM
Doc o
Aug 15, 2013 10:18 AM
bigboy92
Aug 15, 2012 01:47 PM
kamut
Mar 7, 2011 12:29 PM
Mac09Electra
Jul 18, 2010 09:38 PM
