Lifter noise?
Old Oct 23, 2013 | 06:18 AM
12hdrk's Avatar
12hdrk
1. Wood's lifters are a quality product.
2. Wood's lifters are not noisier.
3. Hydraulic lifters are quiet by design.. At least compared to solid tappets.
4. All Wood's products are not noisier.
5. Most top end noise is related to rocker boxes.... Not lifters.
6. You are three feet from 70-90 HP top end of an air cooled, loose tolerance motor.
7. You need a radio or earplugs.
8. You need to ride it and not analyze it most of the time. REAL problems are obvious.
JMHO
Old Oct 23, 2013 | 06:47 AM
Rickr01's Avatar
Rickr01
JMHO
Old Oct 23, 2013 | 07:00 AM
jfarrar30's Avatar
jfarrar30
Gatermans. Woods are nice lifters if you are lucky enough to get 4 good lifters in the same box. I will never waste my time with them again
Old Oct 23, 2013 | 07:07 AM
09 YELLOWBIRD's Avatar
09 YELLOWBIRD
Just a thought.
My CVO 110" motor is known for lifters to go bad around 25k.
Long story short, I had my wrench at the dealer document it every time.
The last time it was really loud and we both thought it was the lifters.
Well it turns out to be something small got trapped in the oil pump. Scared the gearing inside the oil pump and as well as the cam plate.
ESP Warranty took care of everything!
Paid the difference from stock to the New SE billet Camplate and SE High Volume oil pump, the New SE lifters, New SE inner bearings and some other small goodies.
I know aftermarket are better, but my bike is still under ESP Warranty till 2016.
Good news is I was able to upgrade to my Fullsac Sleeper Stage II kit while he was inside there and am very, very stoked with the performance!!
Good luck,
YB
Old Oct 23, 2013 | 09:20 AM
12hdrk's Avatar
12hdrk
Originally Posted by fullautomike
How do your new lifters (Woods I think) compare to the stock ones?
You guys want to hear loud lifters......you should have heard my Sporster with hydro to solid lifters and cams etc....85hp. But it went like hell! Would smoke any stock 103 no problem and then some!
Same. I didn't have much noise I could attribute to lifters. Top end (rocker boxes) is much noisier IMO. Woods lifters seem to be fine so far and I don't anticipate any issues.
Old Oct 23, 2013 | 09:22 AM
12hdrk's Avatar
12hdrk
Originally Posted by NECaveman
Might want to reconsider lifters other than Woods to reduce the noise. I replaced the SE PN 18535-99C lifters with Woods PN WDL-1012 lifters with about no change in lifter noise.
...and what does that tell you? Maybe it's not the lifters???
Old Oct 24, 2013 | 09:04 PM
Jron56's Avatar
Jron56
Stage II
Noise on a 103? Really? Never heard that before. Solution: put a firewall between you and the motor 3 feet away from your ears. Then it will be just as quiet as your cage.
Noise should be out the pipes, not a rattlin-*** sewing machine between
your legs. "Go clean your cage"
Old Oct 25, 2013 | 09:18 AM
reddog8145's Avatar
reddog8145
JMHO
Correct. Stop analysing. You'll go mad if you dont
Cohiba_Joe
Oct 26, 2020 08:17 PM
JONNIEROCK
Dec 30, 2013 06:35 PM
TedMan
Exhaust System Topics
40
Apr 16, 2010 01:12 PM
97classic
EVO
Jul 14, 2009 02:17 PM
jjb
Jun 13, 2009 06:59 AM
