2010 King Classic no start
Old Oct 26, 2013 | 07:35 AM
SKIPSTER's Avatar
SKIPSTER
Default 2010 King Classic no start
I power on, hit the start button, and all power goes out, dash, lights, and no start. Battery is fresh and new. Connections are good. The problem just happened all of a sudden. Stopped for a bite to eat, came back out, the problem occurred, had to get a tow home...any thoughts ?
Old Oct 26, 2013 | 08:01 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Load test the battery at a reliable place, sounds suspect.
Even new!
Old Oct 26, 2013 | 08:12 AM
SKIPSTER's Avatar
SKIPSTER
Yup, did that, the battery didn't drop below 11.8v with a 185amp load for 10 seconds. The bike did power back up once it got back home, tried the starter again, same thing, bang and no power .
Old Oct 26, 2013 | 08:56 AM
Fatboy1389's Avatar
Fatboy1389
check the grounds, same thing happened to me and it seems the culprit was the starter relay ground wasn't tight. It has started every time since I tightened it a few weeks ago
Good Luck!
Old Oct 26, 2013 | 09:03 AM
Northbound Southerner's Avatar
Use your meter and see if you are getting power to the starter when you press the switch. Work backwards or forwards from there...
Old Oct 27, 2013 | 08:49 AM
Dale_K's Avatar
Dale_K
Maybe a clutch switch/neutral switch problem? You'd think it would crank a little or at least click the starter even if the battery was weak. So I'm guessing some kind of interlock is keeping the starter off. I'm no expert though - this is totally an internet guess.
stewy1200c
Apr 25, 2016 08:08 AM
Sporty69
Jul 29, 2012 08:15 AM
ssstubaf
Aug 4, 2010 09:22 AM
rollover
Jul 31, 2007 07:02 PM
ssgtange
Nov 21, 2004 07:49 PM
