Oil spots?
Old Oct 30, 2013 | 07:14 AM
30glock's Avatar
30glock
Default Oil spots?
So my 2012 is spotting, took it out for a spin yesterday and notice a pretty good oil spot. This has been occurring for about 6 weeks after I lifted the on the jack, What could I have possibly messed up under there.? Thanks
Old Oct 30, 2013 | 08:55 AM
hardheaded's Avatar
hardheaded
make sure your oil filter is tight and drain plugs are snug. look closely at the oil cooler adapter,mainly the plugs that are screwed in it.
Old Oct 30, 2013 | 09:00 AM
VTL nut's Avatar
VTL nut
It should still be under warranty so let your stealer have a go at it.
Old Oct 30, 2013 | 09:05 AM
lionsm13's Avatar
lionsm13
Residue from your last oil change, perhaps?
Old Oct 30, 2013 | 09:29 AM
dougbk's Avatar
dougbk
My first thought also.
Old Oct 30, 2013 | 09:38 AM
TWIN CAM 96's Avatar
TWIN CAM 96
What jack did you lift it with?
Old Oct 30, 2013 | 09:43 AM
hvacgaspiping's Avatar
hvacgaspiping
I always wash my bike after an oil change with the pressure washer (being careful around certain areas) to clean any oil off motor mounts and beneath the case. That way I`ll know for sure if a leak develops.
Old Oct 30, 2013 | 10:09 AM
Nute's Avatar
Nute
Check the Transmission Cover on the right side of the bike just behind the floor board. Bolts are notorious for slacking off and oil leaking out the cover. When on kickstand oil runs from the high side (right side of back) to the low side (left or Jiffy Stand side) making it difficult to dagnose.
Old Oct 30, 2013 | 10:31 AM
30glock's Avatar
30glock
Sears red one
Thanks for this Information .
There is a metal plate that seems to protect the oil pan and other components, that plate had a good amount of oil on it some fresh some dried, I cleaned it well on my last oil change, So i think this is where it's coming from. But this happened the first time I lifted the bike on the jack, before that there was no residual or leak, Back to my original question Is there anything under there I could have Inadvertently damaged? Thanks.
Old Oct 30, 2013 | 11:11 AM
caberto's Avatar
caberto
Good advice from others. If you still can't find the leak... Is it leaking from towards the front left side of the engine? If so, check the wire harness coming out of the front of the primary case.
These wires come from the stator inside the primary case. I had a leak I couldn't find for a long time. Dealer checked it out and said I needed a new stator at a cool $500+ (huh??). I told them to hold off on it, brought the bike home, did some research online, and found that this is not uncommon.
It was the stator harness coming out of the primary case; the seal around the harness as it comes out breaks down and leaks. The fix for most people as well as myself was to carefully put some RTV sealant around the seal where it leaks from (after cleaning out the gunked up oil), then let it cure for 24 hours. Hasn't leaked since, and didn't have to spend upwards of $500 for a new stator & labor that I didn't need.
Good luck.
