Thanks for letting me in on this website. This is my first post, so we'll see how it goes. I have an 03 Police Road King, had it since 04 it had 9 miles on it when I got it. In the last two years I have had trouble with the rear breaks, when the pads are about 1/3 worn down the rear breaks just almost go away completely. I had pads basically explode about two years ago and since then I have replaced pads 4 times and the rotor this spring, still same old thing. Pads wear about 1/3 then breaks start going away. There are no leaks, either at the master cylinder of on the caliper that I can see, The resivour is full. System has been bled on more than one occasion. Question is, do I assume the rear caliper is bad and replace or is there something I am missing?
Hi from the UK and welcome to HDF. In addition, measure the thickness of your rotor. If it is close to the wear limit, or beyond, replace it. However don't change things without confirming they need it! An additional thought, when replacing pads, do you check fluid level? It is possible for the system to be over-filled and cause premature wear.
Have you cleaned and inspected the caliper pistons? Could be some corrosion on them. You can try removing the caliper, place something flat and a little thinner than your rotor between the pads, then work the brake to see if the pads are able to compress the distance required. While you have all that piston exposed, clean it up with some brake cleaner. Then pop off the master cylinder cap and spread them back out.
The calipers are crazy easy to rebuild. The kit to do it isn't all that pricey...especially if you get an aftermarket kit.
I would pull the caliper apart, blow-out the lines and rebuild it...there really isn't much to the brake system. It's relatively simple/straightforward.
From what you are describing, it almost sounds like different types of brake fluid got mixed (DOT 4 & DOT 5)...that is 'typically' evident by discoloration of the fluid, but not always. It WILL (I know from personal experience) result in a lack of brake power if you mix the two fluids...it could also cause the pads to stay in (light) contact with the rotor, creating heat and making the pads overheat and get brittle.
Thank you all for the quick response to my questions. Here is what I have done. I have always made sure to only use DOT5 fluid (listed on the master cylinder cap). The Rotor/Disc is within specs (only 5 months old).Bled the system (no air). I don't think the resiviour is over full. So guess next is to pull the caliper, clean it then determine if it's rebuild time or replacement time. If you have any other ideas I would appreciate any and all.
Thanks again.
Hello Marine 22 Welcome to the site. Rebuilding the caliper would be a good idea it very well could be your problem. I would remove it and check for corrosion. I also would not rule out the rear master cyl. as being the culprit. Please keep us informed as to what you find.
