What causes excess oil into intake on a new rebuild?
Old Nov 9, 2013 | 10:39 AM
bagman1's Avatar
bagman1
Default What causes excess oil into intake on a new rebuild?
Can anyone explain why some motors will bleed excess oil thru the intake and others don't? I have a new build and am using oil at the rate of 4 quarts in 3500 miles. If I run the breathers to the ground I don't use oil I've just installed an Arlen ness filter per recommendation from the builder to stop the issue. Well it doesn't work.
Any info from the forum? I'm about to call the builder but he is good at bs'ing and would like to be more informative when I call.
I suppose I could vent to the ground but that just doesn't seem like a fix but more like a band aid.
I'm a mechanic by trade but not a HD wrench, I think I have somewhat of an understanding of how the breather system works. Maybe I am missing something.
As a note on a compression check I have 200 front and 190 in the rear. If 10% variance may be the norm on a 8 cylinder would that be acceptable on a. Twin.
Thanks forum members!
Old Nov 9, 2013 | 10:47 AM
MCCHP's Avatar
MCCHP
The interesting thing is that it does not do it when it is vented into the atmosphere ..
Old Nov 9, 2013 | 10:52 AM
0ldhippie's Avatar
0ldhippie
Could be something out of wack with A/C install but I'd still bet on bad beathers/install.
Old Nov 9, 2013 | 11:10 AM
Am4wag's Avatar
Am4wag
A new/rebuilt (or better put-new rings) engine is going to have a lot of crankcase pressure and vapor because combustion pressure leaks past the rings/cylinder walls.When the breathers are routed to the intake,vacuum from engine is going to pull that excess amount of vapor through the intake.Breathers to atmosphere aren't going to route the vapors through the intake.As engine "breaks in" (rings seat) the crankcase pressure will reduce,as combustion will be reduced from leaking past the rings into the crankcase.How many miles are on your engine?
Old Nov 9, 2013 | 11:25 AM
bagman1's Avatar
bagman1
That's kind of what I'm thinking the reason for the ac change from the SW snorkel he says was causing a positive intake psi and holding the umbrella valves open. My next thought is the rings didn't seat right or he didn't space the ring gap properly. I don't ha e a power loss though
Old Nov 9, 2013 | 11:36 AM
bagman1's Avatar
bagman1
Between 6-7k. I just had an oil sample done and the only elevated thing was aluminum at 31 ppm which they say is acceptable for break in. Which at that time had 4600 on the motor and 3500 of it was 70-95 mph for 12 days at 8 hours almost a day.
Old Nov 9, 2013 | 11:55 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Vent to the atmosphere and forget abt it. As stated, its the neg pressure sucking the oil thru the breather tubes.
Old Nov 9, 2013 | 12:59 PM
bagman1's Avatar
bagman1
So would you say 6-7k it's still seating? I know the comp when new was 150&151 now it's up a lot higher, Ida thought it be done seating
Old Nov 9, 2013 | 08:02 PM
Am4wag's Avatar
Am4wag
Should be seated........
Old Nov 10, 2013 | 07:18 AM
biil9's Avatar
biil9
vent it
