The new JW Evo 2 is better than any other LED light produced so far and is far superior to the Harley Daymaker and costs $350.00 with lifetime warranty. I don't know if it will beat an old Bosch 0 301 600 118 - ECE Motorcycle lamp (LHD) with Osram Silver star H4 bulbs in the corners.
I'm now leaning towards the JW Speaker 8700 Evolution 2 Round 7" LED Headlight - Black for my 14 SGS, has anyone installed one of these yet. Do you need the wiring harness adapter. Also where is a good place to buy one.
Actually in my opinion the EVO is a better and brighter light output...
The EVO 2 has those gray areas in them
There's another video out there that I saw that shows those gray areas in front of the bike
Also the EVO is brighter when he (above) shines the EVO into the EVO 2
If the EVO 2 was better then don't you think that the EVO light would have been lost in the EVO 2?
Personally I thought so
I'm not sure the new design is better then the older design
But hey each to there own...
Paul
Excellent and informative video. If I did not already have the TL7 I would be going this route with their latest version. The downside is they only make this in 7"???? so great for the Street Glide owners but for those of us with running lamps a bummer. I have my TL dialed in very well with both headlight and running lamps. I throw a lot of light down the road and off to the sides, plus all 3 match. Hopefully they (JW) will come out with running lights but until they do I will stick with what I have.
Paul
Hard to say, since it's all relative. Need to see how bright those grayer areas are on the street, and if the EVO 2 is bright enough. I don't need to see a mile, just far enough.
Does anyone know if the HD Reflector LED's beam "color" matches the Custom Dynamic LED Turn Signal Inserts for us Street Glide owners w/o passing lamps?
Yep, I have both. They may not be exact but I can't tell a difference.
