which is the newest 7" LED projector type from the company that makes the Daymaker Projector.... twice the light and much better pattern than the original
Also see that there is a new one from Bagger Nation "something x" or something...isn't available in black yet
For what it is worth. A HD Tech I know said the HD Daymaker came out first. Then the Reflector LED was rolled out to add a European compliant LED to the accessory lineup.
I added the Daymaker projector major improvement over stock dual halogen on my 14SGS. As far as the cutoff I lowered the aim about two inches ,that pretty much takes care of the dark area. Although it wasn't as bad as some say. IMO. The Evo two wasn't available when I ordered mine.
It seems like from what I've been reading, the HD reflector seems to get better reviews than the projector styles (either HD or JW Speaker). Mostly, those without the aux lights seem to have found that it provides more light dispersion (particularly in turns).
I think that's the way I'm leaning myself, but it seems like every time I'm about to pull the trigger I read another review that makes me second guess it. I really want the most light I can get from the headlight and it's a good amount of $ to spend so I'd like to get it right the first time...
I have contemplated the same question on my 2014 SGS. The research I have done show me the same conclusion as others. They lack in the corners. Where the HID beams are the best of both worlds. With that beings said I don't think it would be a worthy upgrade for any 2014 streetglide owners who have the factory HID bulb.
this thing lights up 6 lanes of highway....tree line to tree line....it is impressive....it is a beam of light instead of a flood....but it is a very wide beam.....
Great review and I second it all. PPL say if you don't ride at night, it's a waste of money and I absolutely disagree. 90% of my riding is daylight and when I see Daymakers coming towards me or behind me when I'm driving my car---I CAN SEE THEM from so far away. It catches my attention and I know they're there. So, I luv them for the additional visibility in the daylight. I do notice the slight dip---I don't have aux lights, but I'm okay because none of my driving is on pitch dark roads where I'm riding for hours and making countles 90 degree turns.
It's good to see someone else who feels the money was worth it. We pay so much money to look good....I know I've spent thousands on stuff that just looks pretty...so, I didn't mind spending that little bit on safety
I agree, I just purchased the HD Daymaker. Money well spent for safety. Most of the working commute is early morning and evening so the stock light was fine, but this last fall I rode to Keywest and back and much of the ride was at night. Some of the guys had LED headlight and Daymakers seemed to light up the whole road. I looked at both HD LED style lights (the cheaper HD version looks much like the Truck light with the reflector plate in the middle of the assembly) and the Daymaker which appears to have four separate beam sources....two vertical left and right and two top and bottom......I went with the 4 source LED Daymaker.
IMHO the HD Daymaker Reflector has a great beam. Much more visable to the side than the HD DM Projector. Pricey yes. Worth it? To me yes. Full width and down the road. No problem in turns on a single light SG. Here are 2 pics on a really bright summer day. Low and High:
