Battery cover 2009 Ultra
Old Nov 10, 2013 | 12:39 PM
2009's Avatar
2009
Default Battery cover 2009 Ultra
How do you remove the battery cover on 2009 Ultra?
I took out the 2 bolts on the rear, there is a metal holder of some kind on the front. HELP!!
Old Nov 10, 2013 | 12:44 PM
UppercaseJC's Avatar
UppercaseJC
It just unclips but it is hard to explain. Do you not even have the owners manual for it? If you don't have the manual just study it real close. You will see a way of unclipping the plate to move it out of the way.
Old Nov 10, 2013 | 01:22 PM
EricD10563's Avatar
EricD10563
You have to lift it a little slide it forward it will come off. I grind some of the plastic off with a Dremel making it easier the next time I have to take it off.
Old Nov 10, 2013 | 01:25 PM
grbrown's Avatar
grbrown
If you don't have a manual you can download one by going to the HD website and the 'Owners' tab.
Old Nov 11, 2013 | 08:59 AM
2009's Avatar
2009
thanks for the replies, I have an owners manual and a shop manual, still cant figure it out.
Old Nov 11, 2013 | 09:04 AM
grbrown's Avatar
grbrown
Red face
Call in on your local dealer and ask them to show you. You'll probably kick yourself when you see what is involved, but it will solve the problem!
Old Nov 11, 2013 | 10:16 AM
lionsm13's Avatar
lionsm13
+1.
I took a hack saw and sawed that damned tongue off.
Not really needed that I can see.
PIA!!
Old Nov 11, 2013 | 10:27 AM
2009's Avatar
2009
Alright...Found a YouTube video, battery cubby slides forwards then lifts off front metal latch.
Thanks EricD10563 you win the prize..
No mention anywhere in service manual or owners manual, thanks.
Old Nov 11, 2013 | 02:01 PM
EricD10563's Avatar
EricD10563
Cool, I would still grind/cut some of the material on the cover to make life easier. You can imagine it's even more of a PITA if you have to remove the cover on the road.
Old Nov 11, 2013 | 02:05 PM
jberg's Avatar
jberg
Don't grind anything. It really is easy but you absolutely must clip all of the wire ties holding the assorted cables to the frame rails on either side of the battery or the top cover won't have enough free movement to come off. Once freed, you simply slide the cover forward and tip the rear up a bit and it will come off.
deacesucks
Jul 2, 2014 08:34 AM
2AMGuy
May 25, 2014 03:49 PM
bucket13
Aug 29, 2012 10:15 AM
jamala00
Oct 11, 2009 12:26 PM
Conehead
Sep 2, 2008 09:18 PM
