Fairing Air Temperature Gauge
Old Mar 14, 2007 | 03:38 PM
  #31
russl179's Avatar
russl179
Default RE: Fairing Air Temperature Gauge
< I have read posts about the compass not being all that wippee either>
Wonderul.....I give up.....let there be an empty hole.....
Old Mar 14, 2007 | 03:44 PM
  #32
Sharknose's Avatar
Sharknose
ORIGINAL: russl179
Problem solved. I am going to remove the temp gauge and install the HD compass.
Are you paying for the compass? Of course you are. NOW you know why H-D puts something worthless in the hole--so they can sell you an "upgrade" like oil temp, compass, etc to go there. And the dealer loves it since percentage-wise they make more $$ on accessories than the bike itself. And if you have them install it, there's the labor charge...
Old Mar 14, 2007 | 05:01 PM
  #33
Qball's Avatar
Qball
It's a POS....if your boys are stuck to your leg....it's hot.
Old Mar 14, 2007 | 05:10 PM
  #34
Gutman's Avatar
Gutman
The thing is as good as the weather man. Compass sucks too. Can go to BonerZone and get one for $5 bucks that works better.
Old Mar 14, 2007 | 07:27 PM
  #35
smknflms's Avatar
smknflms
..I'm not sure about speedometer either...had the SG to 110-115 and bike wasn't at rev limiter yet..
Later
Old Mar 14, 2007 | 07:28 PM
  #36
snoopy's Avatar
snoopy
I donot know why but mine is perfect going down the road and who cares about oil temp. What are you going to do if it gets high?Stop and let it cool off!
Old Mar 30, 2007 | 09:01 PM
  #37
zlaneb's Avatar
zlaneb
ORIGINAL: 60mike06FLHX
When it is 30 outside my gauge says 50. That's riding weather.... I like the gauge.
When it is 80 outside my gauge says 100. That's drinking weather.... I like the gauge.
I use it all the time......
Mike....
Down here in Texas drinking temp is in direct correlation to how bad of a week I've had.
When I read the gauge i ask the wife "Can I ride today" Her answer depends on if it is a drinkn' day or a ridn' day. BUT I do think the MOCO ought to fix this POS.
Old Mar 31, 2007 | 05:39 PM
  #38
choochoo's Avatar
choochoo
why should the MOCO spend money to fix an air temp gauge that hasn't worked right for at least 6 years now.
When they know a lot of you will spend more money with them buying the oil temp gauge?
And maybe even more money having it installed by the dealer?
Just more money in their pocket
but just my .02
Old Mar 31, 2007 | 05:54 PM
  #39
Gunney8's Avatar
Gunney8
Could be that I'm wrong, but thought the air temp sensor was afixed to backside of AC backing plate (on stock AC's). I'm waiting for sevice manual and parts manual to verify. If that is true, then the air guage (agree not worth much) is reading the ambient air temp at the throttle body.??..
Old Mar 31, 2007 | 07:10 PM
  #40
nvsteve's Avatar
nvsteve
ORIGINAL: Gunney8
The sensor is inside the fairing. I moved mine outside and it now is pretty accurate.
