Another Fuel Odor Thread
Old Nov 21, 2013 | 01:21 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Default Another Fuel Odor Thread
OK, it's hit and miss with my bike. Sometimes the odor coming out of the fuel vapor vent hose that ends along the left frame rail is none stop.
My bike has been parked in the garage since last Sunday and the raw fuel smell is still coming out of the vent. The tank is full but not to the bottom of the filler hole piece. Yes, there's 5oz of Seafoam in there which may have an affect on the smell.
I taped off the bottom of the vent hose to experiment and the odor escaping has ceased.
The gas caps on our bikes are "vented", right? If so, what's the purpose of this additional vent hose? I'm sure it's there for a reason but right now, I'm afraid to light a cigar in my garage......
Old Nov 21, 2013 | 01:30 PM
mkguitar's Avatar
mkguitar
so that expanding fuel has somewhere to go... ( a vented gas cap is so that air can displace the fuel being pumped out the bottom of the tank)
typically fuel coming out of the filling station pump is cooler, having been underground.
It may expand in the tank...leading to the "full" tank to be overfill and dump on the ground. you may have seen this in parking lots. and that is why the pump says "do not top off".
if your case you are likely smelling some of the lighter fuel additives, which often evaporate first- and maybe the stuff you dumped in the tank
CA bikes and modern cars have charcoal canisters to absorb these fumes- which are then burned when the motor starts.
crack your garage door. gas fumes are heavier than air.
mike
Old Nov 21, 2013 | 01:31 PM
soft 02's Avatar
soft 02
If the tank is vented im not sure the cap is. EPA gives us non vented caps and vents the tank back into the TB.
Old Nov 21, 2013 | 01:45 PM
HDV-GLIDE's Avatar
HDV-GLIDE
Our caps are vented because I thought different too, ordered a non-vented cap and the threads are different and it wouldn't screw on.....Maybe I'll try some of that gasoline fragrance they advertise in car speed equipment catalogs..
Old Nov 21, 2013 | 01:47 PM
HDV-GLIDE's Avatar
HDV-GLIDE
mike
Right you are on the vent process..... had my garage door open for for a period of time over the last several days....Odor was still coming out....Not now, since I taped it up!!!
Cowboy812
EVO
38
Feb 16, 2020 10:29 PM
nehringer
EVO
17
Mar 17, 2014 07:45 AM
01fxdxt
EVO
Jan 5, 2013 02:42 PM
ydnob
Exhaust System Topics
Nov 27, 2006 12:09 PM
Beefcake
Dec 13, 2005 09:11 PM
