Maxi Fuse
Old Mar 14, 2007 | 10:05 AM
RoadKingHellas's Avatar
RoadKingHellas
Default Maxi Fuse
Hi guys,
I am starting this week slowly preparing for the new season here in Germany - taking my road king out from the winter storage ( it stayed in the garage for 5 full months)
Although I took all necessary storage precautions (full tank, fuel additive..etc), I did not use a battery tender . The local dealer good OR bad (we will find out this soon) recommended just to remove the maxi fuse (side panel) in order to avoid draining the battery (the bike is not equipped with an alarm ).
Does this approach of removing the maxi fuse makes sense to you as a minimum precaution at least ? - I believe in the long term this will hurt the battery even if it’s a one year old one .
I better have a battery charger in hand the first time I try to fire the bike ….
Cheers,
John
Old Mar 14, 2007 | 03:03 PM
natewat's Avatar
natewat
Default RE: Maxi Fuse
Well, I have taken the Maxi Fuse out on several occations to install different electrical components but I have always kept the bike on a tender too.
I would be safe rather than sorry, have the charger on hand for the fist crank.
Good Luck and enjoy!
Old Mar 14, 2007 | 04:08 PM
Sharknose's Avatar
Sharknose
If your battery isn't too old your bike is probably going to fire right up regardless of whether you disconnected the fuse or not so I wouldn't worry about that. Also be aware that disconnecting your battery will not keep it fully charged. They discharge over time even sitting on a shelf.
However, pretty much everyone agrees that you will extend the life of your battery if you keep it on a battery maintainer. And with the cost of batteries, getting an extra season out of it is worth the investement.
Old Mar 14, 2007 | 04:31 PM
Lil Truckr's Avatar
Lil Truckr
Get yourself a battery tender where you can direct/hard wire the pigtail on to your battery. Then keep the battery plugged in at ALL times you're not riding if possible. I've been doing this on my '02 since new and I'm stillusing theoriginal battery. Yesterday, after its 5 month hibernation, I went out and unplugged the tender, turned the key and hit the start button and the bike roared right to life. Batteries are just to damn expensive not to take care of them...
bigjosh42
Electrical/Lighting/Alarm
17
Feb 8, 2019 12:52 AM
bigjosh42
Feb 3, 2019 07:40 PM
BadX
Dec 31, 2017 04:52 PM
topbanana3767
Sep 17, 2014 07:28 PM
OneBlackFly
20
Jan 23, 2011 09:31 AM
